Alternator question
Old Dec 16, 2018 | 04:57 PM
jtaylor578578's Avatar
jtaylor578578
Alternator question
Hi I have a charging issue with my 97 explorer I believe my brushes need to be replaced in the alternator. is it possible to replace the voltage regulator brushes with the alternator still in the vehicle? or do I have to remove the alternator completely?
Old Dec 17, 2018 | 09:10 PM
steve(ill)'s Avatar
steve(ill)
better to replace the entire alternator... not just the brushes are worn.
Old Dec 18, 2018 | 09:24 AM
jcris's Avatar
jcris
I don't think its possible to do without removing the alternator first. It should be fairly easy to get outta there. Why do you think it's not charging ? Have you checked it with a voltmeter?
Jcris
A reman alt will set you back about $150, new voltage reg prolly $50 if you can get it. If this volt reg is internal just buy a reman, to much trouble to get put back together right. Make sure you check everything else, belt, pulley, alignment and bracket
Good luck
Hussler
Jan 22, 2011 01:38 PM
sciondude09
Mar 15, 2009 05:59 AM
1960 F100
Aug 28, 2007 09:54 PM
Don2
Jan 17, 2007 05:05 PM
