Brighter dash lights
Old Dec 13, 2018 | 07:27 AM
gogoat's Avatar
gogoat
On my 49 F1 I converted to 12 volt and changed dash light bulbs, Not overly bright. Anyone know of brighter bulbs to get
Old Dec 13, 2018 | 09:04 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Have you tried LEDs? My dash isn't installed yet, but testing with a 12V power supply shows them to be a bit brighter than the originals.
Old Dec 13, 2018 | 12:14 PM
drptop70ss's Avatar
drptop70ss
I am also looking for brighter dash lights, so far I have tried two different LED replacements for the dash bulbs in my 41 cadillac which are similar to the F1. Neither were impressive and neither as bright as a 6v bulb with 12v on it That is the brightness I am looking for, too bad they dont last long like that. Probably have to wire up my own LEDs and try that.
Old Dec 13, 2018 | 01:27 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Really, not to be a jerk but you need to provide better input if you want educated helpful output. What bulbs are you using? There are several of different wattages, so to answer your question properly we need to know what it is you have.
Old Dec 14, 2018 | 11:57 AM
Mixer man's Avatar
Mixer man
When I rebuilt my instrument cluster I repainted the lighting channels with bright gloss white. The original paint was a very faded flat off-white. It made a huge difference to the point where I could probably use a dimmer. I'm also using 5000k LED's. If you decide to do this don't forget to mask off the high beam indicator hole. I'll try to get a pic.
Old Dec 14, 2018 | 01:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
There are two bulbs that are similar sizes but different candlepowers. As I recall, either will fit a '52's dash lights. #53 is 1 CP, #57 has a bigger globe and is 2 CP. The rated life of the 57 is half that of the 53, probably not a concern here. Both are 12v. (MSCD is candlepower in the chart.)
Old Dec 14, 2018 | 03:45 PM
Mixer man's Avatar
Mixer man
#53 (#51 6 volt equivalent) is used in the high beam indicator, cigar lighter, and turn indicator jewell lamp. #57 (#55 6 volt equivalent) is for instrument illumination. Per the Ford '48-'50 shop manual.
Old Dec 14, 2018 | 06:26 PM
Mixer man's Avatar
Mixer man
They are not quite as bright, battery is low because I've been testing with it, but you get the idea. Apologies for the picture clarity.
Painted light channels and 5000k LED's.
terrylamar
Apr 23, 2016 06:15 PM
bluesnake2006
Jun 21, 2015 01:34 PM
helm40
Jan 28, 2009 08:53 AM
chromedaddyo
May 17, 2005 01:10 PM
mchild
Aug 30, 2003 01:08 AM
