SS Window vents?? Install issues
Old Dec 11, 2018 | 10:34 PM
Patdabin's Avatar
Patdabin
So I purchased a set of Rain vents.
for my 1979 F250
I wanted to know who has installed them?
Can you post a pic of screws installed?
Need some guidance thanks everyone
Directions seem unclear to me on spot to drill
Here they are
And the best part the hardware is china junk zinc coated steal. So off to buy ss screws form store.
Old Dec 12, 2018 | 09:43 PM
Patdabin's Avatar
Patdabin
Thank you for the pics and quick answers exactly
Old Dec 13, 2018 | 07:58 AM
CelticOne's Avatar
CelticOne
Regular User
My sarcasm detector is going off ....
Old Dec 13, 2018 | 03:08 PM
njdevil77's Avatar
njdevil77
I have them on my '76 but I did not install them. I will try to get some pics when I get home for y'all, see if you can make sense of it.
Old Dec 13, 2018 | 06:01 PM
Patdabin's Avatar
Patdabin
I have them installed under the edge of the weather stripping now do I need to drill into the window frame
Old Dec 13, 2018 | 07:58 PM
79 ranger 4x4's Avatar
79 ranger 4x4
yes you need to drill 3 small holes per the instructions in the kit to install the retaining screws. If you roll the window down without them they will simply fall off. I just installed some so I recommend getting them where you want and install the center screw first then each end Keeps it centered and allows you to pull each end up tight to the door
Old Dec 14, 2018 | 01:00 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 on yes you have to drill 3 holes, or use small self tapping screws in your upper/top door frame. Test fit and make sure you want them, because that is a nice truck even without them. And use some clear RTV/ sealant of some sort (on the screws) before you install them.
I am not near my truck or I would get you some pics.
Old Dec 14, 2018 | 02:41 AM
diingjp26's Avatar
diingjp26
i just installed EGR in channel today on my '12 Screw and love the way they look. however, the fronts are bit of a pain because the new trucks have one touch front windows and when the window gets in a bind it will roll half way back down. so you have to use the normal power window mode, not the one touch mode.
Old Dec 14, 2018 | 05:55 AM
77&79F250's Avatar
77&79F250
Found some pics of the dirty ol pig with the shades on.
Do not over tighten the center screw...thanks PO. My parts truck had a set also, mounted the same way. Just not over tightened in the center.
Old Dec 14, 2018 | 09:50 AM
fordrealdrive's Avatar
fordrealdrive
That's a fine lookin dirty ol pig Mr.
Old Dec 14, 2018 | 10:15 AM
77&79F250's Avatar
77&79F250
Thanks, it's starting to show it age here and there.
Old Dec 14, 2018 | 08:05 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Ain't we all! Be careful over there Rich.
Old Dec 15, 2018 | 01:28 AM
Patdabin's Avatar
Patdabin
Looks like I have pre-installed them the correct way. I'll go but stainless hardware and drill the window frame. I'll post pics tomorow of pre-install
Old Dec 15, 2018 | 11:26 PM
tbear853's Avatar
tbear853
Yep.
And those screws were always coated steel, never ss, if it worries you put some sealer in holes and on srew threads. Mine has had them since near new, no issues.
landcrazy
Nov 12, 2016 10:51 PM
Jolly Roger Joe
Oct 20, 2015 08:34 AM
Tuxedo Scorpion
6.7L Power Stroke Diesel
32
Apr 25, 2012 05:49 PM
weekendwarriorfsw32
18
Jan 4, 2010 08:22 AM
turboale
Aug 16, 2006 06:36 PM
