I just got this truck and currently have to pop the hood from inside and then use a long screwdriver to horizontally push a short latch that's below the hood latch mechanism that's too short to reach through the grille with your fingers. This can't be the way it was designed - is there a piece missing or maybe the wrong hood latch? Or maybe not the original grille?
There's a secondary latch that you reach through the front grill with your fingers to be able to open the hood. The latch is only a couple inches inside the grill. On mine it opens easier if you push the hood down slightly while moving the secondary latch. Do you have a billet grill that makes it so your hand can't enter the grill?
After you pull the release in the cab, you should be able to slide this lever to the left to unlatch the hood. May have to press the hood down slightly while unlatching.
Definitely nothing like the grille on mine - this is it. Apparently an aftermarket piece. Clearly it provides more protection for the radiator. I guess this would explain why there was a long screwdriver in the glovebox.
I think the point with different grills is to keep rocks from damaging radiator cooling fins.
On my trucks, Explorer and Mountaineer, I add screening material or expanded metal to keep small rocks from costing me big money.
I disagree. They are a cosmetic change to make you truck look different that the next.
Adding a mesh screen to keep bugs and stones would do more than a billet grill. It would only keep those things out of your radiator if you do not have air conditioning since the condenser is in front of the radiator if you do have a/c.
Right - I'm thinking of debris while going down the road. I don't think accident protection is a goal of a grille. I need to rig a pull wire or something, fishing in there with a screwdriver is a pain.
On my truck my cable broke over the wheel somewhere giving me plenty of cable to fish it out to my headlight assembly and I fashioned a pull loop out of the stock cable. My truck's a sweetheart, just nothin to.look at....
