OBS SD Hydroboost (details)
Old Dec 6, 2018 | 05:53 PM
bc4lyphe's Avatar
bc4lyphe
4wd Low
Hi I've been reading up on putting HB in an OBS. I've got a cummins in my 97 and dont have a vacuum pump. Ive got a ZF psp so I'll need new hoses. Im aware the ~87-97 F-SD BRB-37 is a bolt in deal. I cant find one. I have my old vacuum booster and will be reusing my brake MC for now, dually rear drums.
I've read guys redrilling the firewall but it looked to me there was a nut or some sort of hardware holding the mounting plate to the unit itself. I'm wondering if its possible to simply swap my original 4 studded mounting plate with the one off the SD hb unit. Has anyone tried it?
Old Dec 6, 2018 | 06:13 PM
ford390gashog's Avatar
ford390gashog
The push rod is incorrect and the pedal will be to low if you make an adapter for a 99+ unit. I suggest just buying the correct one. I just bought one and paid 270.00 with the core fee. You can also try www.car-part.com and find a used unit complete with master cylinder. That way you have the master cylinder and the critical pushrod.
Old Dec 6, 2018 | 06:36 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Old Dec 7, 2018 | 08:59 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I would like to know the details also.
Old Dec 7, 2018 | 09:26 AM
FORDF250HDXLT
Here you go Jim.
(This is for a complete bolt in deal using the '87-97 F450 parts)
My Latest Project: Hydroboost Brakes
Old Dec 7, 2018 | 02:50 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Originally Posted by FORDF250HDXLT
Here you go Jim.
I guess maybe I misunderstood because I thought he was asking about 99 and up superduty trucks hydro boost master cylinder onto an obs. I have already done the OBS SD conversion on mine. I haven't moved the rod farther up the pedal arm so it is still more effort to push. I did put a proportioning valve in to reduce pressure to the rear to keep the rears from locking up before the fronts
Old Dec 7, 2018 | 09:50 PM
quincyj34's Avatar
quincyj34
I'm starting my swap tomorrow. Found a used hydroboost off a 95 superduty on car-part.com and I will be moving the brake pedal pin as well. Along with constantly reading @FORDF250HDXLT writeup and others I found this helpful too: https://www.powerstrokenation.com/fo...290-post8.html
Old Dec 7, 2018 | 10:41 PM
bc4lyphe's Avatar
bc4lyphe
4wd Low
Well shucks I had no idea about car-part.com. Pretty nifty. If this junkyard SD part doesnt work out I'll get an OBS SD one off there. I'm assuming they dont ship?
Anyways I went to the junkyard and pulled a hydroboost unit off a 2000 ECLB DRW truck for $30, got other goodies as well Was busy so I quickly held it up on my truck. Looked good. I'll double check my photos but I think the pedal pin was the same distance from the pivot. My master cylinder fit right on without having to slot the mounting holes. Two of the firewall studs werent fitting in the stock holes. Ended up knocking them out, welding the holes, and drilling new holes. We'll see how it goes in the morning. If things go according to plan I'll make a post about it with beaucoup photos and measurements.
Old Dec 7, 2018 | 10:53 PM
quincyj34's Avatar
quincyj34
They do. I believe it depends on the place you choose. Im in the panhandle of Fl and my unit came from a yard in Tampa, they charged $132 w/shipping.
SVTDriver97
Sep 1, 2018 05:55 PM
mike1202002
Nov 1, 2016 11:56 PM
fisherman_chuck
Jul 23, 2011 01:29 AM
Opossum
Jun 16, 2010 04:42 AM
jb510
May 11, 2008 10:20 PM
