Removing Master Brake Unit.. Help
Old May 11, 2008 | 05:24 PM
jb510's Avatar
jb510
I need to remove the master brake unit off a 2003 Ford F250 Diesel and see it has the master reservoir and unit attached to the power steering, is there anything special I need to do or should I just take off the bolts that hold the master reservoir on. Im used to taking the whole unit out thru the firewall but I dont think I need to on this since it has power steering attached, Am I correct on this?
Thanks
Old May 11, 2008 | 07:03 PM
DJR96's Avatar
DJR96
Wink
Three hydraulic hoses, an electrical connector, unclip the brake pedal under the dash, and undo the four bolts that secure it to the firewall. That'll get the whole master cylinder and hydroboost unit out complete.
What needs to be done?
Old May 11, 2008 | 07:34 PM
jb510's Avatar
jb510
Ok
When i press on the brake pedal and hod down on it, the pedal slowly just goes down to the floor. I have no leaks and the complete brakes calipers , disc, are brand new, so it either the hydro boost or the master cylinder.
any way to tell which it would be????
Old May 11, 2008 | 09:50 PM
DJR96's Avatar
DJR96
Wink
Yeah. If there's no leaks anywhere, it sounds like the seals in the master cylinder. You won't have to remove the hydroboost at all. Just the brake lines (which I forgot in previous post) and the two nuts to remove master cylinder. I'm guessing that there is a circlip that retains the piston and seals in the cylinder. Remove that and it should all come out. Check the bore of the cylinder that it's not scored, causing the leak down. Hopefully it's not and a seal kit is all you'll need.
A little odd that this should happen to a vehicle thats only 4-5 years old though. Must have been contaminated some time ago. Cleanliness is required. Good luck.
Here's a couple of shots of mine on a naked Navara body:-
Old May 11, 2008 | 10:02 PM
Maxium4x4's Avatar
Maxium4x4
Online manual time 2003 Workshop Manual
Old May 11, 2008 | 10:04 PM
Maxium4x4's Avatar
Maxium4x4
I hate to tell you this DJR96, you mounted the brake on the wrong side of the truck......
Old May 11, 2008 | 10:20 PM
DJR96's Avatar
DJR96
Wink
Ha. That was quick. I knew someone would say that.
Not only is it the right side, it's the CORRECT side, for where I am at least.
bghnkinf250
55
Nov 12, 2017 11:33 PM
bghnkinf250
'80-'86 HOWTO's
61
Apr 21, 2015 10:07 PM
turnrjr
Oct 30, 2012 02:07 AM
BRONC-OH
Bronco II
Sep 4, 2012 08:40 PM
tp4pdb
Aerostar
45
May 30, 2010 12:32 PM
