Sponsored by: Innova
where to go through firewall?
Old Sep 27, 2003 | 02:47 PM
Pass The Peas's Avatar
Pass The Peas
I need to run a power cable from the battery to an amp in the cab. Where's a good spot to go through the firewall? The vehicle type is noted in my signature....
Old Sep 27, 2003 | 03:53 PM
mikewrt's Avatar
mikewrt
I like to go through the firewalls where there is existing oem wire gromets. usually there is at least one medium to large rubber gromet. I just scope out the existing wire positions and the poke through the gromet carfully with a small screw driver or other sharp object. the hole may have to be enlarged to allow a 8 or 4 guage amp wire through. PLEASE BE CAREFUL PUNCHING A HOLE NEAR EXISTING WIRES OR YOU WILL HAVE A BAD AFTERNOON GUARANTEED!
Old Sep 27, 2003 | 08:24 PM
triton_2002's Avatar
triton_2002
This is the way to go, why start drilling holes when you already got plenty. There is one on the driver side under the dash, its directly behind the brake master cylinder if you are standing in front of the truck with the hood open. There are also some holes under the floor sill panels which just pop off.
Old Sep 28, 2003 | 12:06 PM
Pass The Peas
excellent! thanks
axidjw
May 2, 2016 09:17 PM
06SD250
Oct 10, 2010 05:17 PM
No-Tyme
2004 - 2008 F150
Apr 20, 2010 08:29 PM
olelepoint
18
Dec 15, 2009 08:44 AM
trumpboy77
Electrical Systems/Wiring
Oct 14, 2005 12:07 AM
