Sponsored by: Auxito
ignition switch keeps going out
Old Dec 5, 2018 | 03:38 PM
colecamp57's Avatar
colecamp57
we have a 1997 f250 light duty w/ 5.4 triton 4x4. we have replaced the ignition box 4 times. at first it works great and then w/in a week or 2 the key doesn't work. when you turn the key no sound, nothing, then if you let up on the key,release it very slowly it will catch and take off. this last for about a week then that doesn't work either. then we go get another ignition box and it is the same all over again. can someone tell me what's going on. it is a automatic.
Old Dec 5, 2018 | 08:03 PM
Bluegrass 7's Avatar
Bluegrass 7
The key lock assembly has a rod that runs down the steering column to operate the ignition switch.
After the second switch that does not work, find out why the rod is not operating the switch fully.
Old Dec 6, 2018 | 06:40 AM
Mitchapalooza85's Avatar
Mitchapalooza85
X2
My 86 Ford did the same thing, its a switch at the base of your steering column that the Rod engages with.
HERE YOU GO SIR:
Old Dec 6, 2018 | 11:27 PM
colecamp57's Avatar
colecamp57
the video jus shows how to replace the ignition box, and the next video shows a relay gone bad, if the relay is bad why does it work great when you first replace the box and then over time it starts acting up?
Old Dec 6, 2018 | 11:29 PM
colecamp57's Avatar
colecamp57
thank you , at least now I know what to tell them
Old Dec 6, 2018 | 11:31 PM
colecamp57's Avatar
colecamp57
thank you now at least I can explain it better.
Old Feb 8, 2023 | 11:30 PM
cristianvarqas's Avatar
cristianvarqas
1st Gear
Did you figure it out after all? I know this thread is years old but my 01 F150 Crew Cab has been doing exactly this. On my 6th ignition switch now!!
fordguy300
Nov 24, 2008 03:13 AM
jrv
May 16, 2008 08:49 PM
maeleoin
Feb 8, 2008 05:49 PM
cbgv2000
Dec 18, 2006 12:58 PM
Tricky Dick
Feb 12, 2004 08:08 PM
