Sponsored by: Auxito
Evap noid question
Old Feb 9, 2023 | 06:20 PM
Hit Man X's Avatar
Hit Man X
Evap noid question
I found Ohm levels here. 30-90ohm. It tests that fine.
Am I able to hit one side with 12V and one with ground to see if functions or will that kill it internally?
I do have 12V key on at it. I have yet to do test to PCM harness. Truck is smog exempt, just dislike codes.
Thanks guys.
Old Feb 9, 2023 | 06:22 PM
projectSHO89's Avatar
projectSHO89
It helps if you identify what you're working on and why....
Old Feb 10, 2023 | 05:16 AM
manicmechanic007's Avatar
manicmechanic007
Yes, you can test your canister purge solenoid like that
Yes, you can test the evap solenoids as well like that
Active command mode on the NGS does exactly that with a pids to monitor to see if they are functioning
Old Feb 10, 2023 | 02:08 PM
Hit Man X's Avatar
Hit Man X
Whoops.
01 Screw. 5.4/70W.
Old Feb 10, 2023 | 02:50 PM
projectSHO89
.. and why?
Old Feb 10, 2023 | 04:51 PM
Hit Man X's Avatar
Hit Man X
Ah. P0443 code.
I found an older thread pointing out different tests, of which I have completed most. Last is the ground circuit to PCM. Will need to eyeball EVTM for PCM pin.
Valve has Ohm limits within range, but seems to not function when neg pin is grounded and positive is connected. Unless it is not audible
Old Feb 11, 2023 | 08:42 AM
projectSHO89
P0443
Purge valve resistance should be around 34-35 ohms. 30-38 are the limits. If it's over that, the valve has failed that test.
If that passes, the check the line back to the PCM for continuity and for shorts to ground and power. If those all pass, then it's the PCM.
Old Feb 11, 2023 | 02:55 PM
Hit Man X's Avatar
Hit Man X
Roger that, will test and report back when home again.
Thanks again.
Drewf250
17
Aug 14, 2022 12:43 PM
scottddove
Jul 31, 2015 02:02 PM
davidlea
Nov 22, 2011 01:54 PM
PunkysPapa
Sep 10, 2008 09:46 PM
wildspirit78
Dec 26, 2007 02:52 PM
