help finding parts
mr. moderator I apologize if this should have been piggybacked onto a previous post
The small metal box, I bet, is a "voltage regulator" that is really a lot like a directional blinker. It's a bi-metallic strip that heats up, opens a contact, cools off, and close again, and repeats. What this does is maintain a steady overall voltage to the gauges to make them accurate no matter what the battery voltage is. If this "voltage regulator" is bad, either the gauges will not work, or they will register very high.
Calling NumberDummy
D1AZ-10804-A .. ICVR ~ Instrument Cluster Voltage Regulator (Motorcraft GR-513) / Obsolete ~ Available NOS & from auto parts stores.
1978/91 F600/800 /// Misc: 1971/89 FoMoCo Passenger Cars /// 1971/86 F100/350 // 1971/91 Econoline // 1978/86 Bronco // 1983/85 Ranger // 1984/85 Bronco II
D8HZ-10K843-H .. Printed Circuit Board / Obsolete
1978/79 F600/800.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
E2TZ-10848-B (replaced D8HZ-10848-B) .. Instrument Cluster Back / Obsolete
1978/79 F600/800 // 1980/86 B600/700 School Bus.
No Ford dealer or obsolete parts vendor has any.
There are 2 on ebay listed under this Ford part number, applications say Freightliner, but most ebay sellers haven't a single clue what parts fit.
