300 timing question
Old Dec 11, 2018 | 10:17 AM
Tedster9's Avatar
Tedster9
Mixture setting won't spool it up to 1500, no. That's strange, are the butterflies binding maybe?
Old Dec 12, 2018 | 07:48 AM
81F(ranken)100's Avatar
81F(ranken)100
Did it also idle high before switching to manifold (full) vacuum for the distributor vacuum advance? I've heard manifold vacuum can increase your idle RPM. Also, if it is idling "high enough", then the mechanical weights could start to kick in as well.
My only other thought is to verify you have no vacuum or gasket leaks around the carb. This could also increase idle speed? If I recall, another symptom of leaks would be that you are unable to "kill" the engine with your idle adjustments - because even with butterflies closed, air is still entering your intake.
I'm by no means a carb guru, and I know nothing about your particular carb (I've only messed with my stock carb).
Old Dec 12, 2018 | 08:36 AM
ford390gashog's Avatar
ford390gashog
Why would you connect the vacuum advance to manifold vacuum? That causes full advance and if you set the timing like that when under load the vacuum falls off and the timing will severely retard because you didn't have a correct initial baseline.
Old Dec 12, 2018 | 01:40 PM
RMystique's Avatar
RMystique
Idle
No leaks that I'm aware of, and yes it idles high on either port, it's a Holley 4brl, I noticed my secondaires were stuck closed the other day so maybe butterfly issue? And the manifold port gave better low end power, but will see how it does mpg wise, and might change backed to timed port after changing my springs in the dist
Old Dec 12, 2018 | 04:40 PM
Alex from GA's Avatar
Alex from GA
There should be no change in idle RPMs with the vacuum line plugged or connected to the non manifold port. If it idles @ 1500 RPMs I hope you don't have an automatic transmission.
Old Jan 7, 2019 | 03:41 PM
RMystique's Avatar
RMystique
Timing
So i got it running pretty peppy with the 925d springs and 12degrees intial but when i am driving on the freeway and going down a hill, so letting off the gas a bit , it almost has a surge/lurch feeling like it's maybe misfiring a little?
Old Jan 7, 2019 | 05:36 PM
Tedster9's Avatar
Tedster9
Try backing off on the vacuum advance one turn at a time. Don't mess with the mechanical or initial timing at this point, just the vac advance.
‘66 F100 Pearl
Feb 18, 2019 03:30 PM
BrownBadger
Mar 25, 2015 10:36 PM
SideWinder4.9l
Mar 11, 2011 02:58 PM
longjohn69mustong
Feb 19, 2004 01:53 PM
pog
Dec 20, 2000 08:21 AM
