Timing
Old Dec 18, 2000 | 05:29 PM
pog's Avatar
pog
Timing
I installed a Jacobs ignition and it seemed a little sluggish from a dead start. I loosened my distributor and turned it clock wise just a bit. It seems to run alot better with more response and power. Will I hurt anything? What are pros and cons of advanceing or retarding the timing? Thanks Tim
Old Dec 18, 2000 | 10:47 PM
PAUL_2's Avatar
PAUL_2
Timing
What engine , model yr etc ?
Old Dec 18, 2000 | 10:57 PM
jbhf250's Avatar
jbhf250
Timing
Do you have a timing light? What is the initial setting?
__JOHN__Õ¿ö
Member-
"Crusin North" Car Club
Santa Rosa, Calif.
72 F-250
ICQ#6030753
Old Dec 19, 2000 | 07:16 AM
slikness's Avatar
slikness
Timing
First, get a timing light and check what you've done. I believe you retarded the timing somewhat which should give you more low end torque. If you are carburated, then you should be able to run anywhere between 6 and 14 degrees BTDC. The closer to 6 that you get the more low end torque you should gain, the closer to 14..the more top end hp. Your truck will probably run a little hotter closer to 14 but you will also get better gas mileage. A good way to time a vehicle without a light is by advancing the distributor until the engine just starts to ping under acceleration, then back off 1 or 2 degrees. I installed an adjustable timing device from MSD and adjust my timing from behind the wheel. If I'm towing, I retard the timing to 6 or 7 degrees; otherwise I keep it between 13-15. I may retard the timing a little in 100 degree heat just to help the engine run a little cooler.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Dec 19, 2000 | 10:41 PM
pog's Avatar
pog
Timing
My truck is a 1996 f250 with a 460 . I will try to borrow a timing light and check it. Thanks Tim
Old Dec 20, 2000 | 08:21 AM
shotgun's Avatar
shotgun
Timing
