1978 - 1996 Big Bronco
Engine Test plug Help
Old Dec 3, 2018 | 09:03 AM
cemcjoe's Avatar
cemcjoe
I have a 1988 big bronco that someone has cut and spliced back the wires (incorrectly) to the plug that you hook up the code scanner tool too. I have searched google high and low trying to find a diagram showing the wire color and placement of wires in the plug with no luck, I have a Red engine light on and engine is running rough at low RPM's but can not even do the test with a jumper wire due to all the wires being cut. If anyone has a pic or post that will help me it will be greatly appreciated.
Old Dec 3, 2018 | 01:14 PM
vjsimone's Avatar
vjsimone
What engine do you have ?
Old Dec 3, 2018 | 01:17 PM
vjsimone's Avatar
vjsimone
Old Dec 3, 2018 | 01:55 PM
cemcjoe's Avatar
cemcjoe
I have the 5.0 EFI
Old Dec 5, 2018 | 09:48 AM
rla2005's Avatar
rla2005
The Red Engine light is not an indication of a code or issue with the electronic engine controls. A Red Engine light is triggered by low oil pressure or engine coolant overheating.
For reference:
courtesy of miesk5
Old Dec 6, 2018 | 09:54 AM
cemcjoe's Avatar
cemcjoe
Yes you are correct about the red light. Oil sending unit wire was disconnected ,once i repaired it the red light went away. I was able to find another 88 and got the EEC connector off of it and connected it to my wiring harness as it should be and now my scanner works great. Thanks for all the help offered up here you guys are great.
Old Dec 7, 2018 | 08:06 AM
rla2005's Avatar
rla2005
Vinny is the smart one with the pretty pictures for this vintage truck/Bronco.
1992 and up are my strong suit
Glad we could help you out
Old Dec 7, 2018 | 09:36 AM
vjsimone's Avatar
vjsimone
1992 and up are my strong suit , Glad we could help you out
cemcjoe, don't let Randy kid you, I've learned loads of info from him over the years, and have robbed plenty of the photos from him....
Success is always a good thing out here in cyberspace, good luck and come back anytime.
52 USCG Panel
Mar 25, 2017 03:30 PM
ChuckHD
Jun 19, 2015 10:43 AM
jjsfrd
Dec 29, 2010 03:49 AM
conchstew
May 10, 2008 09:41 AM
seawulff
26
Jan 29, 2007 10:53 AM
