Sponsored by: Auxito
Battery light blinking
Old Dec 1, 2018 | 03:51 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Hi all,
my brother has a 2001 with the 4.6, auto regimen cab long bed 4x4. Has roughly 150k on her, last two days the battery light blind is while it's running either at a stop or driving. I just checked and off not running battery jas 12.6volts and running I'm getting 13.10ish. I cleaned the cable ends and that didnt seem to work. I figured the alternator is good becasue I have almost 14 while running (it has a Bosch unit that's six years old PO installed when he sold it to my brother)
am I missing anything to cause the battery light to blink nonstop
Old Dec 1, 2018 | 05:17 PM
Bluegrass 7's Avatar
Bluegrass 7
Sure.
The Alternator controls the charge light by providing a ground to light it...……..when the Alternator is not outputting or the regulator is faulty.
Ever consider the Alternator brushes are worn?
Old Dec 1, 2018 | 07:02 PM
SuperDutyScaler
No not on a quality Bosch alternator thsts only 6 years old
Old Dec 1, 2018 | 07:05 PM
SuperDutyScaler
So even though I'm getting 14 volts while the truck is running your saying the alternator is bad?
Old Dec 2, 2018 | 08:18 AM
steve(ill)'s Avatar
steve(ill)
yes, you need a new alternator......... assuming the plugs and cables are all attached to it.
Old Dec 18, 2018 | 07:41 PM
SuperDutyScaler
Ok I kow its been a little but this is what I did. My brother did not want to buy a new alternator so I cleaned all the terminals on the alternator and battery post. Applied dialectic grease and recheck the voltage...
-truck off battery is at 12.8
-headlights turned on, truck off battery holds at 12 for the ten minutes I waited
-start truck, lights on or off, radio on or off (two 12 subs being powered) a/c on or off, heat on or off, sitting in park or driving I'm getting 14.1 in all scenarios.
Now I haven't heard anything from my brother since my last post when I cleaned everything so could dirty battery terminals be causing the issue? Both post had a ton of blue battery acid build up
Old Dec 18, 2018 | 08:15 PM
Lime1GT's Avatar
Lime1GT
Sure could. Just make sure you're using the dielectric grease properly.
Old Dec 18, 2018 | 08:32 PM
SuperDutyScaler
What do you mean? I put a thin layer on the stud then bolt on the cable, on the alternator a thin film on the brass terminal then install the lock nut
Old Dec 19, 2018 | 08:13 AM
Spotty's Avatar
Spotty
Last week I put a new idler pulley on my tensioner. I pulled the belt off completely to inspect it. Put it all back together and started it up and the battery light was on. I have never got a battery light on that truck. It has the original alternator from 2003 and it works fine. I checked all the voltages like you.....all within spec. So I pulled the negative battery cable, pulled the hot red wire off the alt. and pulled out the two electrical connectors. Sprayed it all down with contact cleaner, let dry and then just a SNITCH of die-electric grease. Put it all back together....light off, been fine for about 10 days. All I can conclude is I bumped a contact that was marginal due to 15 years of use and cleaning them up gave me a solid connection. You may know this but don't put die-electric grease on uncleaned terminals.
Old Dec 19, 2018 | 09:06 AM
alloro's Avatar
alloro
You said when running you're getting 13.10ish which is nowhere near 14. You need a minimum of 13.8 volts to charge the battery.
Old Dec 19, 2018 | 09:07 AM
ford390gashog's Avatar
ford390gashog
Well that's not correct use, the dielectric grease is not a conductor it's a insulator. You never use it on electrical pathways. The cable to post should either have a conductive grease or be clean and dry. Also I about laughed when you said "quality bosch reman" there is no such thing. All bosch parts that are reman and not originally made by Bosch are done by a third party and have a Bosch box.The alternator is no good Based on the charging voltages you provided. What's the reason for not wanting to replace the alternator?
Old Dec 20, 2018 | 01:01 AM
Lime1GT's Avatar
Lime1GT
SuperDutyScaler, That's what I meant by using the dielectric grease properly. You would clean the battery posts and clamps, install them dry, then coat with a dielectric grease or spray.
Amazon Amazon
akblackfoot
Sep 11, 2025 06:34 AM
medic25
Dec 10, 2012 11:24 AM
npccpartsman
Escape & Escape Hybrid
13
Jan 10, 2011 09:08 AM
bagpype
Nov 25, 2010 06:41 AM
duden123
Sep 10, 2006 12:32 PM
