First time death wobble
Posted a still from my dashcam to convey the storm grate...
I would talk to advisors until I found one that is sympathetic to your problem and expresses a working understanding of the most likely causes and solutions. Your alternative is to simply take your truck to a dealership and accept what they decide to do, or more importantly NOT do. As I said, I don't even own my truck yet. However, I have already been discussing DW/SSWO with a service advisor at the dealership where I ordered and am purchasing my truck in northern Arizona. When I raised the issue with him and my desire to have my truck's alignment checked before I take delivery, he was pleasantly eager to do so. He said that he'd give me a printout of the alignment data as the truck was delivered and a printout of the final data if they had to adjust it. We discussed caster, and he was of the opinion that this was something that should be set correctly, not always having been done so at the factory. He also expressed a knowledge of TSB 18-2268, Ford's current recommendation to attempt repair of a truck that has experienced DW/SSWO. So far, I am encouraged that I am dealing with a service department that appreciates the problem of DW/SSWO and has an interest in doing something (their best?) to ensure that it doesn't happen to my truck. As he said, "It is always better to prevent DW/SSWO from happening than to deal with it after it has happened."
As a means of going farther than Ford will, you might consider installing a better steering stabilizer than the “thing” that Ford installs. Since you are still under warranty, you’ll probably have Ford install a new “thing” which will most likely last for another 10,000 to 20,000 miles. If there are other suspension components that are excessively worn and in need of replacement, simply installing a new stabilizer will only mask your problem instead of solving it, and the stabilizer may wear out much quicker. In any event, I would consider replacing a Ford “thing” at around 15,000, keeping an eye on it for signs of fluid leakage. I would also recommend that you take the truck in just before the standard warranty runs out and tell them to check the entire front suspension. In regards to an aftermarket steering stabilizer, I believe that FOX has created a good product, the ATS 2.0 (Part No. 983-02-143 for a 2019), and I am seriously considering installing one on my new truck. I am also evaluating installing both a combination of this upper stabilizer and a lower dual stabilizer using the Kelterman brackets and FOX 2.0 stabilizers (note: these are not the ATS stabilizer). I intend to leave my truck stock height, and the Kelterman brackets will work without a lift. However, I need to discuss this with several people before deciding. It might be too much “stabilization”, but the front end on a Ford 4x4 Diesel Super Duty is so damn heavy that I suspect it is not.
I wish you success in solving your DW/SSWO problem. I do believe that the problem can be prevented from occurring or re-occurring. Please let us know how things go. We all benefit from interactive discussion and knowledge.
