2.5 level alignment advice
Old Nov 29, 2018 | 03:30 PM
Sterling_47ag's Avatar
Sterling_47ag
Originally Posted by TimSchoenborn
Those are the same ones that Carli issued with my kit.
I was right around the same numbers you are mentioning here and the truck drove out pretty good.
I will mention one other sort of related thing here and I was reluctant to do it even based on Toyo telling me to do it along with Carli also. I was running 45 pounds in the front and 40 in the rear on that F-350 6.7 with 35" Toyo AT 2s Extremes. No load or trailering.
It was almost a miracle on how much better the truck drove. I think the inflation might have helped the Caster issue a little to the good for whatever reason?
And my tread wear was as good as it gets. Just a little FYI
Nice! Thanks for all the input. I'm at 55psi on 35in Falken Wildpeaks. Kind of nervous about going much lower. They show very little squat right now at 55psi.
Old Nov 29, 2018 | 03:33 PM
TimSchoenborn's Avatar
TimSchoenborn
No problem I hope it all works out for you!
I was nervous also but the consistent story I was getting on the Toyo ATs is that they have the strongest sidewall in the business.
I grew more and more confident the more I drove it.
Anyway, best of luck with all of it!
150 Beast
2015 - 2020 F150
May 16, 2019 06:07 PM
mstaser
Jul 4, 2008 07:34 PM
BufordinAL
Jun 13, 2006 08:25 PM
omni
Apr 2, 2006 04:27 PM
OddManOut
Apr 1, 2003 08:45 PM
