Regardless, if you really want to know what your oil pressure is, put a mechanical gauge on it, a good one. Even with the proper sender, your dash gauge is just an idea of what the pressure really is.
So I installed the accurate oil sending unit from Dennis carpenter and the oil pressure barley moves when stationary and giving it gas, when driving the gage does not move. Could I have a worn out motor? Oil level is slightly low. 1949 ford f1 flat head six.
So I installed the accurate oil sending unit from Dennis carpenter and the oil pressure barley moves when stationary and giving it gas, when driving the gauge does not move. Could I have a worn out motor? Oil level is slightly low. 1949 ford f1 flat head six.
Even if the oil level is at the "add oil" mark there is still adequate oil. Did you ever check the pressure with a mechanical gauge? There is also a remote possibility that the oil passage at the sending unit is plugged (another reason to not use Teflon tape), and that can be flushed by removing the sending unit and installing a tube into a pan and cranking the engine over (coil wire removed).
Do you know how many miles are on the engine, and have you ever dropped the pan?
No I have not used a mechanical gauge to check, and this sending unit does not have Teflon. I don’t know how many miles are on this engine and I have never dropped the pan. I plan on rebuilding the engine soon though, so that’s really why I have no lt done all of the above.
The redneck way to check if you have oil pressure is to loosen the bolt on the oil filter canister lid. Do not remove the lid, just crack it open a bit. If you have pressure while the engine is running, oil will leak out of the oil filter canister and run down the side. Obviously this is just a quick function check of the oil pump.
Anyone who has replaced the filter and not seated the lid gasket properly has seen this. Or so I've been told, by someone else.
It does sound like an electrical problem as opposed to mechanical, but it's an easy check if you're not sure.
Geez, I might be the one guilty of sharing that story. My 226 puked oil all over my driveway in about 6 seconds. 'Yep, got pressure and the oil pump works!'.
That gasket being properly seated on the filter is pretty darn important.
Tom
