Oil Pressure?
Old Feb 9, 2003 | 08:33 AM
pirsqrd's Avatar
pirsqrd
Question Oil Pressure?
1991 Explorer 187k miles.
Oil Pressure used to be around M or A on the NORMAL guage; now it is down between N and O. Any ideas how I can restore oil pressure without tearing the whole engine down? I change oil every 4000-4500 miles.
I have heard that products like SeaFoam can be used to clean out the block and restore the pressure - anybody have any input on these products?
Thanks for your input.
Old Feb 9, 2003 | 12:41 PM
Opera House Works's Avatar
Opera House Works
Oil Pressure?
You may have a gauge but it doesn't read oil pressure. It is only connected to a 5# oil pressure switch and a 20 ohm resistor fixes it at that position. A little corrosion on the connector and it may read a little different. You need to buy an external gauge to read pressure. Normal ptessure should be almost 60# at cold startup, 45# driving when hot and 20# at idle.
Old Feb 9, 2003 | 04:43 PM
Dialtone's Avatar
Dialtone
Oil Pressure?
Just replace the sending unit. At that mileage, mine started acting up also. Part is cheap and remove/reinstall is easy.
Like previous poster said, sending unit is really a switch that measures wheather you have at least 5 PSI oil pressure or not. Gauge reading is set by a fixed value resistor in the gauge unit. Assuning the wire connection to the sending unit is OK (not corroded) and the sending unit switch is closed, gauge should read about half scale. If you want to prove it, remove the lead at sending unit and ground it with switch on engine off, gauge should read half scale.
If you really want to see a true pressure reading, then you need to modify the gauge/sending unit which is another story.
Dialtone
Old Feb 9, 2003 | 06:56 PM
pirsqrd's Avatar
pirsqrd
Oil Pressure?
You guys are saying that guage is basically an idiot guage - either you got pressure or you don't......hmmm that is disappointing.
Thanks for the info.
jawjadawg
Mar 30, 2017 02:25 PM
pbjlamar
Mar 11, 2013 01:37 PM
bigmike33
Jan 2, 2010 05:17 PM
nlemerise
26
Jul 27, 2006 04:34 PM
binkley
42
Aug 6, 2002 02:43 PM
