Heated mirrors
Old Nov 27, 2018 | 03:28 PM
Headviking's Avatar
Headviking
Heated mirrors
Now that its getting colder, I have noticed that my side few mirrors are heating up and melting the snow off of them. I checked the fuse #39 15A and it looks good. Is there a relay or another way to check to see if current is present at the mirrors? Or is there a replacement (just glass) that can be purchased if that's what I need?
Any advice?
Thanks
Old Nov 27, 2018 | 03:34 PM
seville009's Avatar
seville009
Don’t understand the problem; heated mirrors are supposed to melt the ice and snow.
Old Nov 27, 2018 | 04:46 PM
Headviking's Avatar
Headviking
There not melting the snow and ice. Not sure if the mirrors heater elements are working or if I have another problem in my wiring or relay if there is one.
Thanks
Old Nov 27, 2018 | 05:40 PM
seville009's Avatar
seville009
They don’t get real hot. On my 2011, they’ll defrost actual frost (like a rear window defroster - you’ll see the heating element lines). They’ll help loosen ice and snow, but I always have to brush or chip it off. It won’t turn it to water and dripoff
Old Nov 27, 2018 | 07:33 PM
87crewdually's Avatar
87crewdually
My mirrors get very warm. They actually steam and you can feel the glass get warm.
But I would pop the door panel and get to the mirror plug. With the key on you should have one 12v+ wire (black/white) and a -ground (black) ☆(going by memory on the wire colors, I'll try to confirm). The 12v+ goes to the heater and of course it needs a ground. If you put a test light on the door harness side on those 2 wires it should light. That will tell you the circuit is working.
If that's good then ohm out the heater side of the harness.
heres the plug.
Old Nov 28, 2018 | 09:21 AM
Headviking's Avatar
Headviking
I've seen people on YouTube pop the glass out and have the wires exposed for the heated mirror., but that was on cars not ford trucks.
Now when i do find that there is no power at the heater. where do i look next ?
Old Nov 28, 2018 | 11:51 AM
87crewdually
If no power at the plug then work upstream. Check the relay for function. If relay is functioning when the key is on then I'd put power to the output side of the relay to see if I then get power to the plug. If NO power still at the plug then I'd suspect a broken wire in the door jam rubber boot.
All you're doing is breaking it down systematically to take eliminate items that could be at fault.
Old Nov 28, 2018 | 08:02 PM
Headviking's Avatar
Headviking
Ok now I hear that it does have a relay. Do you know where it is? I could not find it in my manual.
Thanks
Old Nov 28, 2018 | 08:34 PM
MTlariat's Avatar
MTlariat
Fuse #39 is mirror heater
Fuse #39 in interior fuse panel is for mirror heater
Old Nov 28, 2018 | 08:38 PM
MTlariat's Avatar
MTlariat
Mirror heat shut off I installed
I use an upfitter switch to control on/off mirror heater otherwise heat is on anytime the key is on.
Old Nov 28, 2018 | 09:11 PM
87crewdually
The relay is fed power from the ignition through fuse #27. (Check that fuse)
The relay is a part of the central junction block.
Then from the relay power is sent through fuse #39 out to the mirror.
Did you check for power at fuse #39 with the key on? If theres power there then the relay is fine.
Old Nov 28, 2018 | 09:33 PM
87crewdually
Heres the whole schematic.
Fuse #27 is the Hot in Run ON for relay to energize.
Fuse #39 is the power from the relay to the mirror.
Old Nov 28, 2018 | 11:41 PM
Headviking's Avatar
Headviking
Thanks thats what i needed.
Ill check tomorrow.
disker
Mar 4, 2018 09:14 PM
dougasy
2009 - 2014 F150
Nov 29, 2016 07:42 PM
rocks maintenance
Jul 19, 2011 08:39 PM
Matt M, PA
Sep 12, 2009 07:54 PM
james gang 1001
Jul 27, 2007 05:05 AM
