Motor build
Old Nov 27, 2018 | 12:58 PM
bass-n-fire's Avatar
bass-n-fire
Motor build
I have a question. Can I use the internals from a 97 powerstroke on an 01?
i cracked the block on mine a while back. Bought another motor. My plan is to use the internals in the other block. And I plan on using as much of the external parts as possible. So basically all I’m using from the newer motor is the block.
Old Nov 27, 2018 | 02:24 PM
quesey's Avatar
quesey
I did that when I reringed my motor. The lifter holders are different but as long as you have the ones from the later block all should be good. Just make sure to keep the front covers and pickup tubes the same with the oil pan. I cant remember when they changed them
Old Nov 27, 2018 | 02:58 PM
Hussler's Avatar
Hussler
On the 01 it won't have the cam lobe for the mechanical fuel pump, unless you change the cam out. Have to go with electric fuel pump configuration.
Old Nov 27, 2018 | 04:03 PM
bass-n-fire
Can I use the cam from the 97?
Old Nov 27, 2018 | 04:41 PM
quesey's Avatar
quesey
Yes thats what I did
Old Nov 27, 2018 | 09:25 PM
z31freakify's Avatar
z31freakify
If the 01 engine is complete (front timing cover, fuel bowl, fuel lines etc) IMO you should go the superduty fuel system, I did it in mine and its worth it, E fuel is nice but its also $$$.
Bmoodie10
Jun 19, 2018 01:15 PM
Kuskoal
29
Jan 5, 2009 10:05 PM
54fordsd
Jun 3, 2007 05:13 PM
Ford Junkie
Jul 15, 2006 07:58 PM
Freakazoid!
Mar 1, 2004 10:01 PM
