Block ID
Old Mar 1, 2004 | 06:01 PM
Freakazoid!'s Avatar
Freakazoid!
Question Block ID
I just picked up a 428 block from the mechanic I used to work for. He says the motor came from a Shelby KR500. I was just looking at things like the webs to the mains, checking for cross bolts (none), etc. What I really want to know is this: How can you tell the difference between a block that was designed for a solid lifter cam and one that was designed for a hydraulic cam? I've seen pictures of the internals that describe the differences, but nothing that distinguishes the outside. Any ideas?
Old Mar 1, 2004 | 10:01 PM
fordman428's Avatar
fordman428
well one thing the 428 never came with cross bolted mains, if you find a block that does its either a late 406 or a 427 as for a solid lifter or hydraulic cam differences i dought you have one the only ones that came with solid lifters was the 66 428 police interceptor, if the block is designed for a solid lifter cam it would have the blocked oil galleries.
