360 fe engine build
Old Feb 9, 2019 | 01:25 PM
85e150's Avatar
85e150
Threads merged..
Old Feb 9, 2019 | 03:20 PM
ford 315's Avatar
ford 315
yes flat top with valve relief.want to get the most torgue with out going to a stroker kit.was told the way to go is 390 crank and rods and pistons.so this set up i have is stock u think or aftermarket.
Old Feb 9, 2019 | 03:36 PM
85e150's Avatar
85e150
It's stock. Measure how far down the cylinder the top of the piston is at tdc.
The way to torque is displacement and cylinder pressure. More compression and more efficient cylinder filling are the ways to higher cylinder pressure.
Coleton_henry
May 5, 2017 09:39 PM
ford-power-f250
Dec 30, 2012 07:45 PM
millertime300
Dec 3, 2003 08:09 PM
gtex
34
Apr 24, 2003 11:22 AM
big block power
15
Oct 24, 2002 04:26 PM
