360 engine
Old May 5, 2017 | 07:08 PM
Coleton_henry's Avatar
Coleton_henry
360 engine
Hey, I'm looking to build the 360 engine in my Highboy, I'm wondering what the quickest way to increase horsepower and torque is. Im looking for around 350-400 Horsepower.
Old May 5, 2017 | 09:39 PM
85e150's Avatar
85e150
Crank, rods and pistons. IF your current pistons are in good condition and in spec with the bores, you can reuse them. The crank and rods would be 390 crank and rods. With your pistons you would increase displacement to 390 and raise compression from the low 8s to the mid or high 9s, depending on the piston top and actual combustion chamber size.
Add headers, a decent 4bbl intake and carb, and the old 390GT cam, and you would be in the ballpark power wise.
If you don't want to go that way, just install a smallish 4bbl and headers, fiddle with ignition timing and call it a day. Several here report noticeable gains with that set up.
For more on the 360 and other FE variants, read on here:
https://www.ford-trucks.com/forums/forum51/
ford 315
17
Feb 9, 2019 03:36 PM
YoungMT Hick
Aug 21, 2011 05:44 PM
mjshagnaty
Aug 26, 2009 05:18 PM
biggut
Dec 31, 2004 09:09 PM
ebenc
Apr 23, 2004 02:01 AM
