360 fe engine build
Old 02-09-2019, 01:25 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,719 Likes on 1,404 Posts
Threads merged..
Old 02-09-2019, 03:20 PM
ford 315's Avatar
ford 315
ford 315 is offline
yes flat top with valve relief.want to get the most torgue with out going to a stroker kit.was told the way to go is 390 crank and rods and pistons.so this set up i have is stock u think or aftermarket.
Old 02-09-2019, 03:36 PM
85e150's Avatar
85e150
It's stock. Measure how far down the cylinder the top of the piston is at tdc.
The way to torque is displacement and cylinder pressure. More compression and more efficient cylinder filling are the ways to higher cylinder pressure.
Coleton_henry
05-05-2017 09:39 PM
ford-power-f250
12-30-2012 07:45 PM
millertime300
12-03-2003 08:09 PM
gtex
34
04-24-2003 11:22 AM
big block power
15
10-24-2002 04:26 PM
Quick Reply: 360 fe engine build
