Forscan question
Old Nov 26, 2018 | 12:26 PM
FirstFord18's Avatar
FirstFord18
Forscan question
Switched to the gt blue theme on my super duty and I have had some issues. I changed all 3 codes in APIM.....7DO-01-02-0xxx xxxx xxxx / 7DO-02-01-xxxx xDxx xxxx / 7DO-03-01-xxxx x4xx xxxx. My steering wheel volume control works but displays 0 volume on the circle on the screen that use to ramp up clockwise as you turned up. No volume on screen when a phone call is present. When a phone call comes through now the radio will not notification ring so if your cell phone is not turned up and you are not staring at screen you will miss the call. Also when you go into sound settings the bass, treble, mid is maxxed out on screen....you can adjust, change screens and when you go back it is maxxed out again. Weird things.....anyone else experience this?
Old Nov 26, 2018 | 11:25 PM
mhoefer's Avatar
mhoefer
I haven’t tried to mess with these particular APIM lines. I hope you saved some notes or the original versions for reference. My advice would be to first reset them all to original codes. Reset, and test and make sure is all working well, properly. Then, the next thing I would do is try one of each of the three at a time, separately, before changing all three. One of two or three things could be happening, one, the codes are incorrect for your truck, you could have made an error in entering the codes, or the three are somehow interacting to give you these results.
crazyodaz77
May 19, 2019 09:33 PM
Deadboy214
Mar 15, 2019 01:33 PM
DetailerDave
Jul 24, 2016 11:46 AM
RobertJohn
Dec 15, 2004 09:34 AM
