302 Cam
Old Nov 28, 2018 | 11:45 AM
Steve Harlow's Avatar
Steve Harlow
Set the truck weight to 4500 pounds, any option on any motor for the 5000+ setting doesn't show results, frankly i don't know why it's even there. I thought it was busted too.
It's even got a prospective dyno thing that projects your performance. Hot rod magazine tested it on a build they were doing and claimed it was accurate to within 3 horsepower, and the power curves were dead on. Those are the numbers i got from the prospective heads i want to buy, looks mighty pleasin' to me.
Old Nov 28, 2018 | 12:32 PM
EBEAR's Avatar
EBEAR
What are you putting it in ? That seems very heavy . It's interesting to set it up then change carb size , heads , exhaust or other and see the horse power - torque changes with the same cam .
Old Nov 28, 2018 | 12:35 PM
Steve Harlow
My F3. Based on the rated max GVW of 6800 pounds, i reckon it's somewhere around 5100 pounds stock, and the 302 and m5r2 is probably heavier than the stock flatty and whatever the hell trans it used to have.
Old Nov 28, 2018 | 04:05 PM
EBEAR's Avatar
EBEAR
The problem with mine is they don't have provisions for stoker engines so I just have to estamate .
Old Nov 28, 2018 | 08:50 PM
willymakeit's Avatar
willymakeit
Originally Posted by EBEAR
Did you download the camquest , fill out as many questions as you can and still not get any options ?
Gonna try again it says site is down
ffjoey
22
Apr 29, 2021 08:41 PM
Bootlegger's Deluxe
30
Jul 11, 2017 09:46 PM
resto-mod
Jan 17, 2013 11:20 AM
4Speeds4Ever
Mar 19, 2011 01:46 AM
wills79
Jul 14, 2005 10:00 AM
