302 cam selection
Old Jan 16, 2013 | 06:32 PM
resto-mod's Avatar
resto-mod
302 cam selection
so im building a 302 for my truck and need some input on what cam to use. ive got a a freshly remanufactured longblock. so c/r is somewhere between 8 to 1 and 9 to 1. ive got an edelbrock performer rpm intake, holley 650 dp carb and longtube headers. highest i plan to rev is 5000. comp cams 268h looks good to me but i dont know enough about cams to be sure. i was also looking at a crane cam with 216 216 duration @.050 lift, a 110 lsa, and .484 .484 lft. i dont want to change valve springs so i believe my absolute limit is .500 lift. im using a top loader 4 spd and a 9in with 355 gears. might upgrade to 3.73s. 31in tires
Old Jan 17, 2013 | 11:20 AM
Conanski's Avatar
Conanski
What vintage block and heads? Overall your initial cam choice is pretty sensible but you would be crazy to use a flat tappet cam if your block is roller capable as the benefits are substantial, the roller setup will cost 3 times as much however so it's not a free lunch.
ygoldsberry
Mar 25, 2012 10:41 AM
93F22A6
May 12, 2009 05:46 PM
bigblueovalman
Dec 31, 2007 02:18 PM
smallblock351w
Mar 6, 2007 09:47 AM
weirdjoe3
Dec 1, 2003 12:59 PM
