Custom tuning
Old Dec 3, 2018 | 08:42 PM
  #61
HDSlowride's Avatar
HDSlowride
Originally Posted by bcg
It's not quite the same, there are lots of different places to get the sodium needed for saline. Urea only comes from one place. I'm just passing along a fun fact.
You are wrong. Bad info isn't a "fun fact", it's just bs.
Old Dec 4, 2018 | 10:52 AM
  #62
bcg's Avatar
bcg
Urea is the chief nitrogenous end product of the metabolic breakdown of proteins in all mammals and some fishes. The material occurs not only in the urine of all mammals but also in their blood, bile, milk, and perspiration. In the course of the breakdown of proteins, amino groups (NH2) are removed from the amino acids that partly comprise proteins. These amino groups are converted to ammonia (NH3), which is toxic to the body and thus must be converted to urea by the liver. The urea then passes to the kidneys and is eventually excreted in the urine.
https://www.britannica.com/science/urea
Maybe they can make synthetic urea for DEF, I can tell you with absolute certainty that the urea I was using as fertilizer was not synthetic though, it came from sewage. I still used it, it's organic and a good source of N, especially the water soluble version that I sprayed for immediate uptake and green-up.. If they are making it synthetically, I think that's dumb and wasteful since most of us literally flushing urea down the toilet several times a day.
Old Dec 4, 2018 | 01:38 PM
  #63
HDSlowride's Avatar
HDSlowride
Well, we aren't talking about adding organic fertilizer to our DEF tanks (which contains numerous compounds incompatible with scr systems). I can tell you with absolute certainty that commercial urea production has been in use for many decades and consists of industrially produced ammonia and carbon dioxide.
Old Dec 5, 2018 | 09:32 AM
  #64
Overkill2's Avatar
Overkill2
Man, this thread went all over the place. I hope the OP comes back to let us know how he made out and what he went with.
Old Dec 5, 2018 | 05:41 PM
  #65
kper05's Avatar
kper05
Yeah. If no action has been taken, I still think the OP needs to return to stock and then decide where to go from there, whether that's leaving it stock or considering Ski's experience. The engine just doesn't currently seem healthy to me.
I think these types of threads more easily end up all over as the various components get discussed. There are differences in experience and opinions in the types of tunes or the hardware used. Further, some just want to make a change because they can, some want to resolve issues minor or major, some have factual and reasonable concerns about modifications and a few are concerned the Earth may crack in half tomorrow but the discussions here I thought were good. I think sitting down for lunch would have resulted in the same multi directional outcome!
Old Dec 6, 2018 | 10:03 PM
  #66
Overkill2's Avatar
Overkill2
Oh, I'm definitely with you as I thought the discussions were good. I just wondered how he made out and to get more info from him. But if someone wants to keep it going, by all means, go for it.
Old Dec 7, 2018 | 07:59 PM
  #67
remhaust's Avatar
remhaust
Originally Posted by cangim
Speed is a good input when referencing highway or interstate mpg. For me I get 15-16 at 80-82, quickly dropping if there is a head wind. On the lower end towing small enclosed(7x16)trailer with construction limiting mph to 55, I get 22 which is fantastic, though for this family, our adhd kicks in and say go 80 as soon as the speed limit flips.
As stated b4, everyone’s mileages will differ most of the time just as stated. But I think the biggest that I find comical that not many discuss is the wind. I drive all over and I can tell u I seen ranges of 4-6 mpg just from wind. But then I find another discussion about mpg and all the thoughts n question of why, how, ect. It’s not rocket science. Most of the time,lol
Old Dec 7, 2018 | 08:13 PM
  #68
remhaust's Avatar
remhaust
But don’t take this wrong, this is still good info from everyone comparing info. I will also ad that if you can I would remove egr immediately & tune of some sort or it will kill your diesel sooner or later.
Old Dec 7, 2018 | 08:51 PM
  #69
cangim's Avatar
cangim
driving against wind is my lot in life, same as always the slowest line at Costco.
Old Dec 8, 2018 | 09:04 AM
  #70
goatram's Avatar
goatram
At some time you need to recognize the cashiers. Our Local Store has both fast and slow ones and I do move to get the better ones.
Less than a thousand Miles till warranty expiration. Have been toying with the Idea of deleting. Have Noticed that Items in my cart @ Alligator Performance are no longer available. When I called them up they were stressing that there was no need to remove the Cooler and to run a stock pipe end with just a connecting pipe to replace the Particulate Filter (Bazooka). No Stage III Items Available.
Y'all keep me abreast of the current events on my truck. Thank you. Urea is Cow ****. Easy enough to get and refine to be High Grade DEF. Why over think it?
Old Dec 9, 2018 | 01:05 PM
  #71
Overkill2's Avatar
Overkill2
My experience has been that if you run a lot of short trips with an empty truck, and have frequent conditions where you shut the engine off prior to the completion of an ongoing regen cycle, then a regen will run the entire 40 minute cycle if that much driving time is available. A cycle that long will consume about 2 1/2 gallons of extra fuel based on my real time observations of engine run time and fuel consumed.
As per this old comment of mine: "Mine usually go 18 miles and usually at around 500 mile intervals. But my last one did go 26 miles;" this last regen went off at 500 miles and lasted 17 miles. I was on the expressway I normally take it on when in regen. It's uphill and EGTs got up to 900s. I switched to Trip A which I zero out at every fillup along with the fuel mileage gauge and it read 12.8 mpg and 3.5 gallons used. After Regen was over, it dropped to 11.8 mpg and 5.3 gallons used for a total of 1.8 gallons used during the 17 mile regen AT 75 MPH. I sure would have liked to have the Trip data before AND after that 26 mile regen. Including the fuel used to run the engine and the extra fuel for the regen, 1.8 gallons doesn't sound like a lot.
Old Dec 9, 2018 | 01:15 PM
  #72
Overkill2's Avatar
Overkill2
From what I've read, you don't need to remove the EGR cooler to delete. But there are plate kits out there. https://www.thoroughbreddiesel.com/sd-egrd-6-7p-fp/
"Thank you. Urea is Cow ****. Easy enough to get and refine to be High Grade DEF. Why over think it?"
Good stuff...
Old Dec 10, 2018 | 08:19 AM
  #73
bcg's Avatar
bcg
A week ago Saturday, I drove to Houston with an empty trailer on a calm day and got 11.3MPG. This past Saturday, I made the same trip with the same trailer into a 15 - 20 MPH headwind and got 9.3MPG. That's a big differnce.
Old Dec 15, 2018 | 11:22 PM
  #74
Power_Stroking's Avatar
Power_Stroking
I personally think deleting is a good idea. I have been inside hundreds of these engines and see the amount of carbon that builds up everywhere. I don’t think you would eat your own $**t so why would you want your engine to do it as well which is essentially what egr does. With a good not pre canned tune that helps the engine run more efficiently you would be able to expect some more power and better mpgs, however as you get into the higher horsepower tunes don’t expect the latter of the two.
Old Dec 15, 2018 | 11:34 PM
  #75
jimmystoys's Avatar
jimmystoys
Knew I was onto something...
