Where does the check engine light originate from?
For the "Check Gauges" light(if engine is too hot or loose oil pressure) you will use pin #12 of C251, BUT I recall there is a small PCB hooked on the cluster that monitors the temp and oil sensors and outputs on pin#12 if either one is out of safe range.
As you are making up a instrument cluster with better gauges, I would not worry about the pin#12 of C251. Just use the pin #9 of C251. That pin goes back to pin #17 of the ECU for the "Check Engine" light to work
on
Thank you very much gentleman. I wouldn't have been able to do this project with out you.
Merry Christmas to you and yours.
PS, I almost started terminating unused wires last night but I figured I'd wait until the project was test ran and the bugs were worked out first to be on the safe side. Close one.
I redid engine bay wire harness on my 89 F250 and after wrapping it up, found some issues that snuck in. Not fun destroying a freshly wrapped harness.
Happy Xmas too
on
@subford Just doing my double and triple checks here.
Which wire should I be using for the Low charge / Low battery warning light?
Lt Grn with red strip?
I thought I was looking for an output wire instead of an input?
The Red with Lt. Green is being hooked to a 12V source to activate the alt and I can't see that being used for a warning light. Or am I wrong?
F-250 WARHORSE
02-06-2018 10:11 PM
AbusedAmericanRust
11-16-2015 01:10 AM
pecanguy
08-31-2013 08:09 AM
