Dana decipher
Old Nov 23, 2018 | 11:01 AM
72CC428's Avatar
72CC428
Dana decipher
Hey guys I could use a little help here. I want to order all my stuff for my rear end; brake shoes, brake cylinders, bearing, race, seals gaskets and gear oil. I want to order the parts but I want to make sure I get the right ones the first time.
Also. If anyone knows the best place to order the parts I would appreciate any sharing. I believe the drums are 2 inch but I haven't pulled it apart yet.
I tried using the dana library but that didn't prove fruitful.
Here is the data plate for the axle:
Old Nov 23, 2018 | 11:10 AM
mrpotatohead's Avatar
mrpotatohead
I got my brake stuff from Rock Auto, You don't need Dana info for common, standard brake parts. If you do need Dana hard parts I recommend Torque King 4x4. They have done me right.
Old Nov 23, 2018 | 11:28 AM
72CC428's Avatar
72CC428
Thank you much. Also here's my Data plate guys. My GVWR is 8100. Front axle: 3300 and rear is 5300. I don't really understand these numbers yet. Seems like the GVWR should be 8600 lbs?
Old Nov 23, 2018 | 12:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 72CC428
Here's my Safety Standard Certification Label. My GVWR (Gross Vehicle Weight Rating) is 8100 lbs.
Front axle: 3300 lbs. capacity and rear is 5300 lbs. capacity.
No such thing.
D0TA-BG = Dana 60 Rear Axle / 3.54-1 / No Limited Slip / 5,300 lbs. Rear Axle Capacity.
Assembled 5/72
F25 = F250 2WD
H = 390 2V
R = San Jose CA Assembly Plant.
P27302 = 1972.
This is the Safety Standard Certification Label, glued to the left B pillar (door post) below the striker plate.
Warranty Plate riveted to the left door face below the latch, post a pic of it.
Your F250 has either 12" x 2 1/2" front/rear drum brakes, or if it has optional dual piston caliper front disc brakes, the rear drum brakes are 12" x 2 1/2."
Old Nov 23, 2018 | 01:05 PM
72CC428's Avatar
72CC428
Thumbs up
Thanks Bill! I knew the VIN but you answered my question for shoe size. I have the front disc dual piston calipers. Now the bearings/races and seals are next.
The plate on the door that you mention I took it off when I stripped the doors. I think I have a pic of that in here somewhere. I will find it.
Old Nov 23, 2018 | 01:18 PM
72CC428's Avatar
72CC428
Here's the data plate
Old Nov 23, 2018 | 02:19 PM
NumberDummy
Here's the Warranty Plate
F25 = F250 2WD
H = 390 2V
P27302 = 1972.
131" Wheelbase.
R = Medium Ginger Metallic.
F253 = F250 2WD .. 8100 lbs. GVWR
C 4: C = Pastel Parchment Vinyl / 4 = Styleside Pickup.
G = C6.
37 = Dana 60 Rear Axle / 3.54-1 / 5,300 lbs. Rear Axle Capacity.
8,100 lbs. Gross Vehicle Weight Rating.
163 net HP @ 3,600 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Nov 23, 2018 | 03:10 PM
72CC428's Avatar
72CC428
Question
Bill, is the 27302 the trucks serial number? I see serial # referenced regarding fitment on parts.
Old Nov 23, 2018 | 03:43 PM
NumberDummy
The Serial Number is the last 6 digits of the VIN: P27302.
1972 Serial Number range: M40,001-Q00,000
Old Nov 23, 2018 | 03:50 PM
72CC428's Avatar
72CC428
I'm looking at a wheel bearing/seal kit that advanced auto parts has here for $150 but it doesn't look right. I've never worked on a Dana 60 before so I can't judge if this is right but it looks like it has 4 bearings but 3 different sizes? Is the outer bearing on one side smaller in diameter?
Old Nov 23, 2018 | 07:38 PM
NumberDummy
1969 F250 Dana 60 from serial number F30,001 & 1970/79 F250 Dana 60:
There are two bearings and cups per side.
2) C7TZ-1239-A .. Rear Wheel Bearing Inner & Outer Cup / Stamped with BIN: LM-104911
2) C7TZ-1240-A .. Rear Wheel Bearing-Inner & Outer / Stamped with BIN: LM-104949
BIN: Bearing Industry Number that auto parts stores and bearing shop go by.
Old Nov 23, 2018 | 08:50 PM
72CC428's Avatar
72CC428
Thumbs up
Thank you Bill.
Sturm
Apr 2, 2019 07:39 PM
john jamieson
Feb 16, 2018 06:23 PM
Jimmy nz
Jan 31, 2018 10:55 AM
newguy399
Aug 13, 2016 10:22 PM
chuckbiscuits
Jul 9, 2011 10:02 AM
