Rear brake backing plates
I'm in the process of cleaning up the parts on my Dana 44 and noticed that there is a tab/ear missing on each of my backing plates. Same side on each one. What are their purpose? Can I weld new pieces on? Continue to use as is? Or must they be replaced? For the last option, What years might be interchangeable?
Thanks.
john
Thanks.
john
You know I've been looking at that piece for 50 years now without ever giving it any thought. But since you asked. The only purpose I can think of for that piece is to stop the piston from falling out of the wheel cylinder if it is way out of adjustment.
You should probably replace them. However if it was on my truck, it would be on my searching parts list and I wouldn't hesitate in driving the truck like that. Just make sure your brakes stay adjusted.
Tabs made as part of the backing plates.
B9T-2211-A Right & B9T-2212-A Left .. Backing Plates / Obsolete
2WD/4WD: 1957/65 F250; 1966 F250 with 12 1/8" x 2" brakes; ditto 1967 before serial number B12,001.
GREEN SALES CO. has 2 right sides (800-543-4959). No one has the left side.
newguy399
08-13-2016 10:22 PM
jtindale
19
03-08-2013 01:29 PM
karljay
05-11-2001 08:02 PM
