How's it Starting?
Old Jan 21, 2019 | 07:48 AM
  #31
Walleye Hunter's Avatar
Walleye Hunter
8* here this AM. One full cycle (2 minutes) of glow plugs and a key recycle to reset them. 2.7 second start. A miss or two at first start (and of course some white smoke). but didn't last long. Engine has 184,000 +- on it.
Initial voltage: 11.9V
Key on: 10.4V
Key on+ 20 seconds: 10.7V
Glow plugs off: 11.3V
Old Jan 21, 2019 | 10:25 AM
  #32
Markus Luukko's Avatar
Markus Luukko
-1* F outside this morning
2 cycles of the glow plugs (Wait till light on dash turns off)
Started up quickly with no issues.
4* Oil temp
Trucks got 312K Miles
Old Jan 31, 2019 | 07:57 AM
  #33
Walleye Hunter
-1* here this AM 2 cycles of glow plugs, one more recycle to reignite them and about 3 second start. Romped a bit for about 20 seconds, smoked for a while.
Old Jan 31, 2019 | 09:54 AM
  #34
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
27* ambient temperature
60 seconds of glow plugs on via stopwatch
1 - 1.5 seconds of cranking before truck started with no romping
High idle at after about 20 - 30 seconds of running until I bumped throttle to shut it down
Old Jan 31, 2019 | 10:42 AM
  #35
Dan V's Avatar
Dan V
-32 this morning, -28 yesterday morning....got up to a high of -20.....Never even tried.
I did however have to move some hay with the Case 1845C....plugged it in for 2 hours....wouldn't crank fast enough...added the 200amp booster charger...got my hay moved.
Old Jan 31, 2019 | 06:32 PM
  #36
RA101725's Avatar
RA101725
Banned
Around 2 or 3* F this morning and it started fine. I could tell the batteries didn't like it though compared to "normal" cold temps around here. Fuel mileage really goes to crap this time of year.
Old Jan 31, 2019 | 06:35 PM
  #37
RA101725's Avatar
RA101725
Banned
IIRC it's not even recommended by the owner's manual to try to cold start it down that low. (Without plugging it in I mean)
Old Jan 31, 2019 | 08:41 PM
  #38
StrokedRanchero's Avatar
StrokedRanchero
-20 Yesterday & again this morning. I 've got an early '99 w/260,000 & synth. rottella. I have never plugged the truck in, in the 13yrs. I've owned it. She started with several cycles of Wait to Start, rompted very badly but started. Smoked so bad, I couldn't see the back of the truck for about 5 min.
Old Feb 1, 2019 | 06:48 AM
  #39
Walleye Hunter
Sweet! Do you have anything special in there for batteries? Mine cranks a little slow at -1 and I can't imagine what it's like at -20.
Old Feb 1, 2019 | 08:16 AM
  #40
Firefighter 1406's Avatar
Firefighter 1406
I used to experience a lot of the same results during cold starting. Just a FYI for all that I installed a small trickle charger for the cold months. The truck has remote started all winter with no issues. Do have a bit of blue smoke on start up but other then that she has been starting well. Even with the last few days in the negative 40’s for the wind chill, she has been firing right up.
Old Feb 1, 2019 | 10:13 AM
  #41
StrokedRanchero
2yr old 850 cca Everstarts . I seem to get 4 yrs out of them, with everyday use.
Old Feb 1, 2019 | 12:02 PM
  #42
Walleye Hunter
I'm glad to hear it's treating you well, I was worried that I might have to go hide my head in shame.
Old Feb 1, 2019 | 01:43 PM
  #43
dmd's Avatar
dmd
Wind chill is only important for warm things like humans. No matter the wind chill the truck will only get down to ambient temp... Now ambiant
is still darn cold.
Firefighter 1406
26
Apr 13, 2019 07:52 AM
JTyler11688
Jun 24, 2009 09:27 PM
jayc3169
Dec 28, 2008 05:12 PM
superduty4x4
18
Jun 2, 2008 04:15 PM
F0rdF0rever
Apr 2, 2004 04:15 PM
