voltage meter
Old Apr 2, 2004 | 10:11 AM
F0rdF0rever's Avatar
F0rdF0rever
voltage meter
How low is the meter supposed to go just after starting? Normally the neddle in my truck would sit on the N for a several seconds. Now, last coulpe of day, ive noticed it sits below the N for several seconds. Is this an indication of my batteries going south? The batteries have been in the truck for 3 years and 3 months now. Think its time for a change?
Old Apr 2, 2004 | 10:17 AM
TJC1989's Avatar
TJC1989
I'm no expert, but it sounds normal. Don't the glow plugs continue heating for a few seconds even after the engine starts, and continue to draw quite a bit of amps? What happens after a few seconds? Does your voltage levels return to 13 -14 volts?
Old Apr 2, 2004 | 10:53 AM
F0rdF0rever
TJC1989, Yes, after a few seconds it returns to 13-14. But what im trying to say is the needle seems to go lower than it used to.
Old Apr 2, 2004 | 11:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Inspite of whats been said about the glow plugs so far, I'd go have my batteries tested. My X started doing the same thing when the batteries started dying. But the glow plugs are indeed whats causing the load on your batteries. Don't wait too long to have them tested though. If do they end up dying on you, having to jump two batteries isn't the least bit fun. It almost took cars to get mine started. Even when you jump it and get it started, when you turn it off and have to restart later on don't wait for the glow plugs. Just turn the key and go, the plugs will suck whatever power you have out.
Old Apr 2, 2004 | 01:28 PM
cangim's Avatar
cangim
I know what you are talking about, mine has started dipping lower and lower, we are back into the warmer season, so I am hoping I can wait until fall before I need to replace mine, still originals OEMs 99 350. keep my fingers crossed.
Old Apr 2, 2004 | 04:15 PM
gseeders's Avatar
gseeders
I would service your batteries if you haven't already done that! I have 89000 on the original batteries, I believe that anything below 8 volts while trying to crank is a battery that is going south. I would replace both at same time if and when you need a battery.
gseeders
carl2591
Jan 25, 2015 10:07 PM
2000EX7.3L
Jan 5, 2013 11:37 PM
tlk50
Feb 23, 2010 05:37 PM
Jimmygunz3
Sep 11, 2009 11:42 PM
tom2131968
1978 - 1996 Big Bronco
25
Oct 27, 2006 09:28 AM
