Dana decipher
Dana decipher
Hey guys I could use a little help here. I want to order all my stuff for my rear end; brake shoes, brake cylinders, bearing, race, seals gaskets and gear oil. I want to order the parts but I want to make sure I get the right ones the first time.
Also. If anyone knows the best place to order the parts I would appreciate any sharing. I believe the drums are 2 inch but I haven't pulled it apart yet.
I tried using the dana library but that didn't prove fruitful.
Here is the data plate for the axle:
Assembled 5/72
F25 = F250 2WD
H = 390 2V
R = San Jose CA Assembly Plant.
P27302 = 1972.
This is the Safety Standard Certification Label, glued to the left B pillar (door post) below the striker plate.
Warranty Plate riveted to the left door face below the latch, post a pic of it.
Your F250 has either 12" x 2 1/2" front/rear drum brakes, or if it has optional dual piston caliper front disc brakes, the rear drum brakes are 12" x 2 1/2."
Thanks Bill! I knew the VIN but you answered my question for shoe size. I have the front disc dual piston calipers. Now the bearings/races and seals are next.
The plate on the door that you mention I took it off when I stripped the doors. I think I have a pic of that in here somewhere. I will find it.
F25 = F250 2WD
H = 390 2V
P27302 = 1972.
131" Wheelbase.
R = Medium Ginger Metallic.
F253 = F250 2WD .. 8100 lbs. GVWR
C 4: C = Pastel Parchment Vinyl / 4 = Styleside Pickup.
G = C6.
37 = Dana 60 Rear Axle / 3.54-1 / 5,300 lbs. Rear Axle Capacity.
8,100 lbs. Gross Vehicle Weight Rating.
163 net HP @ 3,600 RPM
72 = San Jose (NorCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
H = 390 2V
P27302 = 1972.
131" Wheelbase.
G = C6.
I'm looking at a wheel bearing/seal kit that advanced auto parts has here for $150 but it doesn't look right. I've never worked on a Dana 60 before so I can't judge if this is right but it looks like it has 4 bearings but 3 different sizes? Is the outer bearing on one side smaller in diameter?
There are two bearings and cups per side.
2) C7TZ-1239-A .. Rear Wheel Bearing Inner & Outer Cup / Stamped with BIN: LM-104911
2) C7TZ-1240-A .. Rear Wheel Bearing-Inner & Outer / Stamped with BIN: LM-104949
BIN: Bearing Industry Number that auto parts stores and bearing shop go by.
Sturm
04-02-2019 07:39 PM
john jamieson
02-16-2018 06:23 PM
Jimmy nz
01-31-2018 10:55 AM
newguy399
08-13-2016 10:22 PM
chuckbiscuits
07-09-2011 10:02 AM
