Questions on shock length
Is shock length measured from eye to eye of the mounts? That's how I measured what I have...
FRONT
Ride height- 21.25
Compressed- 16.75
Extended- 23.5
REAR
Ride height- 28.125
Compressed- 21.625
Extended- 31.5
If it's not measured eye-to-eye, how much do I need to subtract from my measurements?
*edit*
I have heard that one should allow for at least 1/2" of travel at each extreme as you don't want to bottom the shock internally or overextend it either. Bottoming would seem to be a fairly "hard" figure, with some form of unpleasant contact being the ultimate limiting factor. I'm not sure I understand topping to be the same though - if it's simply the extension of the springs that stops the axle from dropping, this would seem to be a dynamic measurement that could vary with inertia (like if the truck "aired out" at speed as opposed to being lifted by a floor jack). Bottoming is a fairly easy measurement, but I'm still wrestling with which Bilsteins to put on the rear... I think I'm going to get the suspension installed and do actual measurements of fully topped before I make a selection.
There are 2 broad catagories in shocks to factor in, “Short” and “long” bodies.
Your front shock example, has a 6.75” travel Didn’t you go with a 8” travel spring ?
For the rear, I did the same thing to measure for extension. For compression, I measured similar to the front, based on where the bump stops I am fabbing up are going to be.
At any rate, I have been looking over tons of manufacturers' shock specs, and they all list compressed and extended length, but I don't see many of them listing travel. One thing I do notice is that most of them I look at have a compressed length shorter than my measurements and an extended length greater than my measurements. Would that mean I would be safe with those, as they would never bottom or top out?
just out of curiosity what are your measurments front and rear.
edit......never mind, Post 1 is your measurments....I took it as the measurment of the shock you are considering
https://cart.bilsteinus.com/Portals/...g-2018-WEB.pdf
I have the same question on picking a shock that has "a compressed length shorter than my measurements and an extended length greater than my measurements". My guess is that we are safe if there is a margin of at least an inch on either end - most of the shocks I have been looking at provide that on compression, but not sure yet on full extension. And I'm concerned that extension can be more than what is measured in the garage, given a situation where a truck fully compresses over a bump and then launches into the air at speed. I guess if your rebound is correct, the unsprung weight can't get too out of control and extend the springs excessively.
I also thought about a cheap set of Gabriel Pro Guards just to get by while saving for a higher quality shock, but they don't list much info either, and let's face it- they are 30-dollar shocks! I'm about half afraid that just taping $120 to the axles would have the same effect...
But I totally get it, as I'm there right now - seems like it costs $500-$1200 every time I look at this truck. I keep telling myself that someday the list will be shorter. Hasn't happened yet...
For the front, I have some choices. two of them have 255/70 valving (33-186542, 33-185552), two of them have 360/80 valving (33-230320, 33-230344), and one is intended for dual shock applications with a valving of 170/60 (33-104645).
Out of these options, which would be the best way to go with what I have up front? (ATS "X-codes" with the Zone mini pack).
Just for curiosity, when you run dual shocks, do you double the valving numbers or is there a formula or ratio that you use to figure the combined valving?
the numbers Bilstein uses are in Newton Meter of force with the first number representing rebound and the second number being compression.
Now, while a shock setup can be roughly figured out by doing the math the reality is ride quality is subjective and leaves a good bit of subjective room for diffrent setups. ( ask 10 racers what the best setup is and you’ll get 12 diffrent answers )
that said, If I recall your front spring rate is off the charts stiff and as such you don’t need much compression dampening since the high spring rate will take care of that. The bad news is you will need a ton of rebound dampinging to control the high spring rate. Obviously that puts you in a custom shock valving catagory with something like 360/30 however if I were to choose one off the rack I would go with the lowest compression valving as that will give you the best ride, I’d choose the 170/60
fwiw.... my Ex is 4 linked and I run a Bilstein coilover, currently have a 600 lb spring and run 20 on the compression.
it rides ok on the street but not ideal, i’ll Be switching to a 450 inch lb spring rate with a 255/70 valving as a start as soon as I get around to
I used the spring because I had it laying around and was experimenting but got tired of shock tuning for the time being.
Shock running a single 3.5 shock.
(edit....full disclosure, I can’t tune that but I hang out with the guys who do and have been involved in the process )
