New build for Blue
"I'm writing you to get help on camshaft selection for my new 408 Ford build. I've pretty much come down to three different camshafts. The comp cams 270H [K32-224-4], the 270S [K32-237-4], OR the ThumpR [K32-600-5]. I'm really wanting to run the ThumpR, but I'm worried about vacuum in a 78 Bronco. I’m sure both of the 270 duration cams will give me much better vacuum, but I have no problem throwing a vacuum canister on if needed. Out of the two 270 dur cams, I'm leaning towards the 270S, but I just can't pull the trigger yet. I keep watching the video in the thread "intake shoot out", it's in the 335 engine forum https://www.ford-trucks.com/forums/1...shoot-out.html , and 470+Hp and 500+ftlb from a Big ***** ThumpR camshaft just gets me thinking. With our engine builds being so similar, maybe the tamer ThumpR would be just bad *** in my Bronco. But it comes down to vacuum. I figure I need 10" or so of vacuum to make it all work. The camshaft is the last bit I need so I can get a properly sized converter.
Thank you for your time.
P.S. Of course if you have a special flat tappet grind I can get from you, that’s better, I would be interested in that also. Here is a break down of my build,
VEHICLE, What kind of car is this for? 1978 Ford Bronco Ranger XLT 4x4
Vehicle usage? (in order of importance) street performance & presence, towing a 3500lb camping trailer to and from the trail head, dunes, and mild trail riding. No big rock crawling, no deep mudding, no baja racing. Most if not all my off-roading will be dunes or dirt trail.
Is it a full body car? YES
How much Does the car weigh? 5400Lbs. (2650lbs front / 2750 rear)
ENGINE, What size engine do you have? 408ci Ford (4.030"Bore x 4"Stroke-335 Engine Series)
Is your car carbureted or Fuel injected? Fuel injected, 850cfm, 4x55lb injectors (FiTech Go Street EFI 400 HP 31003)
Do you have a carb spacer? YES
What size Spacer? 1" four hole Phenolic plastic (Summit Carburetor Spacer SUM-G1412)
What kind of intake is it? aluminum Dual Plane (Weiand 8010 Action+Plus)
What kind of heads do you have? aluminum (Trick Flow® PowerPort® Cleveland 195 Cylinder Heads TFS-51617203-C00)
What is the CC chamber rating for your heads? 72cc
Valve size? 2.08" intake 1.60" exhaust
What rocker ratio? 1.83 (Scorpion Race Series 1060 rocker arm)
What pistons are you running? Tim Meyers .030 over (KB2347) 13.3cc step dish pistons.
[decked -.001 with .041 head gasket, total .040 squish]
What is your COMPRESSION RATIO? 9.89 static/8.13 dynamic with intake closing @ 61*ABDC (all three cams above have this intake closing point)
What size Headers do you have? 1-5/8" Fenderwell exit 3" collectors (Hedman Street Headers 89366)
Are you running open Headers? NO
What kind of mufflers are you running? 3" Super Turbo Mufflers (Dynomax 17743)
Are you running- True Dual exhaust? Yes
What Size Exhaust pipes are you running? 3" pipes x 24" length, mufflers, then dumped in front of rear tires
DRIVE TRAIN, What Trans? 78 Ford C6 (wide ratio gears [2.72-first,1.54-second], PML deep sump pan, Broader Performance stage 1 valve body, Sonnex type R servo, Alto Red clutches, Kolene steels, and a KEVLAR® high performance band)
Transfer case? NP205 (1.96 Low Range)
What axle? D44RS front / Ford 9" rear (alloy axles front and rear, front with solid spicer U joints / rear with nodular housing and daytona pinion support)
What is the GEAR RATIO? 4.11's rear with a helical gear limited slip (Richmond Powertrax Grip Pro Differential GT109031) / 4.10's front with lunch box locker (USA Standard Gear (SL D44-30) Spartan Locker for Dana 44 differential with 30 spline axles)
How Tall are the tires? 33.25" tall as the vehicle sits (35x12.5-15 BFG all terrains, not a typo, the BFG's run SMALL!) NOTES: Can't think of anything at this time."
Shoot away guys!
my exhaust, as it sits.
Pic of the engine as it sits. Getting pulled for rebuild.
I'm sure you mean MECHANICAL flat tappet.
I'm starting to think you have never ran a good set of heads. I have Comps 252H ran strait up in the bronco now and it will turn 5k NO PROBLEM. A 270 dur cam, whether solid or flat, will do much better power wise. Solids are also dead nutz reliable while allowing the engine to rev more freely. Also I kinda miss setting valve lash. Did it all the time in my sand rail with a 2110 VW engine. Hell I almost miss carb adjusting, no not really. LOVE my Fitech!
NOW that I think about it, I should get the ThumpR ground as a solid and run that!
I can see it on a high lift race engine where you your trying to squeeze every hp out of it that you can.
But on a moderate to low lift daily driver or mild street engine it seams like a waist of time to me.
Industrial, ag and big rig engines today still run some type of solid lifter cam and go for thousands of mile or hours without having the valve covers off.
The ever dependable Chrysler slant 6 was solid lift up until 1980, just before it was dropped from production, many never had the lash adjusted unless it got to running bad.
Unless they've changed in the last few years the Cummins Diesels in Dodge pickups are still flat tappet solid lift.
I had a .600 lift solid lifter cam in a 289 Mustang back in the 80's, I'd check valve lash each spring when I'd get the car out for summer driving, car wasn't driven during winter months.
And @ Baddad457, I never said what you say I said. I never said you didn't run cams or big engines. I said "I'm starting to think you have never ran a good set of heads". You do this a lot. putting words in other peoples mouths.
ThumpR 32-600-5 vs Generic RV grind (summit 5200)
Adv Dur =278*/296* vs 282*/292*
.050 dur =226*/241* vs 204*/214*
lift intake/exhaust= .506 /.493 vs .489/.512
lobe separation =107 * vs 112*
intake centerline= 102* 107*
advance ground in.= 5* vs 5*
intake opens= 37* vs 34*
intake closes= 61* vs 68*
exhaust open= 80* vs 83*
exhaust closes= 36* vs 29*
Overlap= 73* vs 63*
Edit, @ badda457 just wanted too add that I only disagreed on the one point. I do agree with the benefit of the set and forget of a hydraulic cams.
