4 speed automatic with overdrive?
Old Nov 22, 2018 | 03:57 PM
fordguy76's Avatar
fordguy76
I know that an np205 transfer case will bolt to the zf manual transmissions if you notch the tail shaft to clear the transfer case shifter linkage. I would assume that the E4OD would have the same tail housing belt pattern. You could also just use the Borg Warner transfer case from the late 80s early 90s although they are not as strong as the np205, but unless you are doing some serious off roading it shouldnt matter. All the trucks that had those transfer cases are still on the road.
If you are looking for better mileage, the later model transfer cases might be better. They are smaller and lighter. They are chain driven as far as I know. Maybe someone else knows more about them.
Old Nov 22, 2018 | 05:41 PM
Shortbox4x4's Avatar
Shortbox4x4
GV setup is nearing the top of my list of the next things to get done. Would like to get it done over the winter/early spring. I’ve done a ton of searches etc....and I keep coming back to the GV. My mechanic has done a couple on some other vehicles and he said the same thing. Go with the GV.
Old Nov 23, 2018 | 06:54 AM
rob8210's Avatar
rob8210
The big question for me is how much did this GV upgrade cost you?
Old Nov 23, 2018 | 07:43 AM
Shortbox4x4
Your looking at about $3k.
Old Nov 24, 2018 | 10:41 AM
meangreen92's Avatar
meangreen92
Just a heads up: I was reading Hot Rod Magazine, and I saw an ad for Tremec which stated that they sell a 4 speed automatic with overdrive. I don't know anything about it beyond that however.
Old Nov 25, 2018 | 06:36 PM
351Cleveland C4's Avatar
351Cleveland C4
GV are great solutions for some situations, but I wouldn't use them for a couple of reasons. #1, they are way overpriced. #2, they just add stress to your current transmission and non-lockup torque converter, which in turn produces more heat. Heat is the enemy....
You Can get an adapter plate and run an AOD for a lot less than what a GV costs. And you'll have a lockup converter which makes a big difference just by itself.
Build the AOD using 4R70W gear set and internals, you'll have a very strong transmission that doesn't require any electronics, has lockup, a lower first gear, and a higher overdrive ratio.
Or swap to a manual trans....
This is my 2 cents.
bewford
Jan 4, 2010 08:55 PM
the truck
May 12, 2008 07:06 PM
fixsford
Engine Swaps
Nov 6, 2007 10:41 PM
wozxxx86
Oct 20, 2006 10:28 PM
cedarman
Jun 25, 2003 09:19 PM
