automatic overdrive
Old Jan 3, 2010 | 10:11 PM
bewford's Avatar
bewford
automatic overdrive
does anybody know what the first year ford put a automatic overdrive behind the 351m, 400, 460. looking to go overdrive with my 78 4x4.
Old Jan 4, 2010 | 01:10 AM
460/5's Avatar
460/5
Zombie Survivalist
i THINK the A4OD is the first four speed they used. not really sure. not sure it the bellhousing bolt pattern is the same or not either.
Old Jan 4, 2010 | 07:46 AM
LARIAT 85's Avatar
LARIAT 85
Ford never put a automatic overdrive behind the 351m, 400, or 460. The first Ford Automatic Overdrive transmission (AOD) came out in 1980. This was a completely mechanical, light duty transmission. If you had a full size truck, you could only get it behind the 302 engine.
Old Jan 4, 2010 | 10:51 AM
droppedf100's Avatar
droppedf100
It was the E40D from late 80s F250 and F350 trucks. It is the only od trans Ford made for the 385 series bolt pattern and its computer controlled. I think from 89-97 they were made. AODs can be purchased with the correct bolt pattern as well.
Old Jan 4, 2010 | 11:33 AM
bewford's Avatar
bewford
well so much for an easy auto overdrive, guess its on the next idea.
Old Jan 4, 2010 | 01:23 PM
460/5's Avatar
460/5
Zombie Survivalist
there are companies that make a bolt-on external overdrive for automatics. for the life of me, i cant remember the names of em though.
Old Jan 4, 2010 | 01:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Gear Vendors make an add-on overdrive. Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
Old Jan 4, 2010 | 01:47 PM
460/5's Avatar
460/5
Zombie Survivalist
thank you! thats exactly who i was trying to think of!
Old Jan 4, 2010 | 08:55 PM
droppedf100
The gear vendors are a ton of money. Either go with a AOD modified for a bbf FB Performance Racing Transmissions - Chevrolet, Chevy, Buick, Olds or get an E4OD out of a late model 460 truck and buy a Baumann trans controller Electronic Performance Products -- Baumann Electronic Controls, LLC and program it with a laptop. The controller is around $400 and is stand alone to work with a carb motor.
