Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Air brake stoplight switch
Old Nov 15, 2018 | 09:46 PM
Jeffrey Ferrell's Avatar
Jeffrey Ferrell
This part seems to be eluding most parts stores in my area. I have an 84 F800 with air brakes. I usually have to tell them its a F8000 to show my correct engine size (10.4 cat)
Old Nov 16, 2018 | 12:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Get the ID number from the original then look at this 13480 stop lamp switch application chart for it (#). I see two possibles. SW is the Motorcraft part number prefix.
Old Nov 16, 2018 | 07:07 PM
buzzinduzzin's Avatar
buzzinduzzin
identify switch
Are you sure the switch in the picture is the brake light switch? Every truck I have seen has two connections (wires) . But I have never messed with any airbrake fords!!
Old Nov 16, 2018 | 07:20 PM
ford390gashog's Avatar
ford390gashog
Go down to any truck place and get the Eaton replacement.
Old Nov 16, 2018 | 08:24 PM
NumberDummy
Pic: 13480 at the outer left is the brake (stop) lamp switch.
Old Nov 17, 2018 | 07:16 AM
big job's Avatar
big job
Maybe its my old eyes; I see one wire: If so that means its a ground going to a relay. New one on me in my
life time, Always been two wires one hot the other to lights. If thats the case with a jumper try grounding that
terminal see if lights come on. Or maybe a oil pressure sender for idiot light works on ground. In Bills picture #13480 sure looks like two wire terminals. I learned yrs ago tell those parts guys nothing just say I need air
stop light switch Not I need switch for a 1956 Ford = they all now are computer geeks. Note if you are sure
this is a ground terminal just go and buy a normal switch and ground one terminal and the other goes to where
ever that relay is .............................
Old Nov 17, 2018 | 07:58 PM
Jeffrey Ferrell
This is the only part that even comes close to matching what im looking for, and its not a ford part. It says its a brake pressure warning switch. Is it the same thing, as a brake light switch?
Old Nov 17, 2018 | 08:13 PM
buzzinduzzin
NO it is closed until a certain pressure is reached then it opens thus shutting off the buzzer or warning light . Look closely at the picture number dummy supplied ; the stop light switch has two terminals
Old Nov 17, 2018 | 08:20 PM
Jeffrey Ferrell
The only switch on my pedal has a single terminal. The wire continues up into another terminal, but its not a switch. (Pictured above) Every light works except the brake light.
Old Nov 17, 2018 | 08:34 PM
Jeffrey Ferrell
I think i got it now. I found the switch. I was in the wrong part of the brake pedal assembly.
bernette
Feb 16, 2019 03:04 PM
columbia1spring
Jun 25, 2018 01:11 PM
95fiveoh
Apr 26, 2018 04:58 PM
madsonp
18
Mar 3, 2011 04:09 AM
Kerrie
Feb 4, 2008 09:55 PM
