Need some purchase advice
Old Nov 15, 2018 | 12:11 PM
Jesse Parrott's Avatar
Jesse Parrott
Hey I am getting ready to buy this I just wanted an opinion on the deal 7k for
2005 350 6.0 powerstroke short bed
235k runs good bullet proofed minus studs.
New all LEDs lights every light
Have New style tow mirrors in box
8 reman injectors
Hpop
Stc fitting
Stant tubes
Head gaskets
Turbo
Ipr
Icp
Ficm
Blue spring
Radiator
Ac parts
Egr delete
4in straight pipe to 10" tip
Upgraded oil cooler
Front brakes
Has scratches and dents but over all a good truck. Runs and drives great has some small blemishes all cosmetic.
Old Nov 15, 2018 | 08:07 PM
Ford.Dude's Avatar
Ford.Dude
https://www.ford-trucks.com/forums/9...used-6-0l.html
This is from the tech files in the 6.0 sticky section.
Old Nov 16, 2018 | 05:28 AM
bismic's Avatar
bismic
$7k doesn't sound bad, but you need to get a scan tool and do your research. Lots of things to look for on the test drive. Make sure you get to test drive it when it is "stone cold" and keep testing until fully warmed up. Testing at start up when cold and when hot can tell a lot.
The list of work you posted "sounds good", but it all depends on what parts were installed and who installed them.
Specifically find out what brand (as well as aftermarket or OEM) was installed for:
Head gaskets
Injectors
Turbo
Oil cooler
IPR and ICP
FICM (ie OEM rebuild or a rebuild from someone else)
Radiator
I would also want to see receipts and know about any warranties for the work.
That is a lot of money to put into a truck to sell for only $7K
hwybee22
Jul 19, 2018 01:27 PM
Nitrodude
Mar 5, 2015 11:05 PM
eaglewwit
Jun 10, 2014 03:37 PM
landscapeguy
Mar 31, 2013 08:23 PM
EXbowtieguy
Oct 8, 2011 08:48 PM
