Many Codes
Old Nov 13, 2018 | 07:43 PM
steveamann's Avatar
steveamann
Many Codes
94 F250 5.8 Engine light came on , it died was able to restart. Pulled key off codes 638,117,112,327,654,513,553,555,556,558. Is my computer bad?
Old Nov 14, 2018 | 12:00 PM
steveamann's Avatar
steveamann
Key on my mistake
Old Nov 14, 2018 | 12:18 PM
rla2005's Avatar
rla2005
Most of those codes indicate the engine/transmission may not be up to operating temperature before running the Key On Engine Off (KOEO) tests and Stored Code display.
The key error code is 513: Failure in EEC processor internal voltage.That is a fatal failure in my book. Clear the codes, warm up the truck, then run the KOEO/CM routine again. If Code 513 is still present, time for a replacement computer or at the very least you could have bad capacitors that may be replaced.
Old Nov 14, 2018 | 02:37 PM
steveamann's Avatar
steveamann
Thanks will try this afternoon
Old Nov 14, 2018 | 02:50 PM
vjsimone's Avatar
vjsimone
Engines are easier to diagnose over the internet when all the codes are listed, and in order of test.
KOEO - (O) Self-Test Codes =
KOEO - (C)(CM) Continuous Memory Codes =
KOER - (R) Self-Test Codes =
Make sure your A/C, Heat, Radio, etc. are turned off when testing.
Do you have any Non-Stock modifications?
(Air Intake? Smog System? Exhaust System? Ignition System?)
Old Nov 17, 2018 | 05:33 AM
steveamann's Avatar
steveamann
Turned out to computer the capacitors were corroded and the wires to board were split. Pretty sure it was the original so guess lucky it lasted.
Old Nov 17, 2018 | 09:59 AM
vjsimone's Avatar
vjsimone
If it's not to late, capture all the numbers and codes off your original computer.
kfcoltn
Aug 29, 2016 11:34 AM
jlinn06
Apr 16, 2016 08:32 AM
eljefe007
May 30, 2013 03:32 PM
sadrok
1983 - 2012 Ranger & B-Series
Jun 7, 2005 08:40 AM
paradiddle
Feb 10, 2004 07:42 PM
