Sponsored by: Kumho
Tire question
Old Nov 13, 2018 | 11:50 AM
hydroracer's Avatar
hydroracer
Tire question
THe tire issue is very confusing for me..I cirrently have a 2013 FX4 supercrew..the tires are 275/55/20...I am wanting to "fill out" the stance of the truck..I have a level kit on it now..I don't want to jack it up or anything but just fill it out so it looks more beefy i guess..what size would i need..i really have zero idea as of what avenue to go down to accomplish this..so I figured I would ask you all! I appreciate the help out front..
also where is the best place to buy parts...looking for a roll bar and nerf bars..
Old Nov 13, 2018 | 01:12 PM
seville009's Avatar
seville009
If you want to keep the exact same tire size, your only choice is to get a tire with beefy treads, something like a Goodyear Duratrac.
Old Nov 13, 2018 | 01:14 PM
hydroracer's Avatar
hydroracer
Think i am wanting taller tires not really wider tires if that makes sense
i do like the duratrac tires
Old Dec 17, 2018 | 08:48 PM
AK4x4's Avatar
AK4x4
If you install a LT285/65R20 it will be about 2.5" taller and about half an inch wider. Good luck, Russ
Old Dec 18, 2018 | 12:41 PM
rsylvstr's Avatar
rsylvstr
the truck will sit 2.5" taller or the tire will be 2.5" taller so therefore you get about 1.25" overall height of the truck?
I'm dumb when it comes to tires.
I have the same set up and am doing Bilstein 5100s in the rear...someday I will get to the front and set on 1.5-1.75" (whichever the 3rd setting is)
Old Dec 18, 2018 | 08:01 PM
Chuckfx4350's Avatar
Chuckfx4350
Overall height will be 1.25”. But know that tire sizes vary from manufacturer to manufacturer. I would recommend a 295/65/20 that is essentially a 35” tire and only 11.5 inches wide. Check out the Nitto Ridge Grappler. It has an aggressive look but great road manners. I have had several sets on my Jeep and trucks.
Old Dec 31, 2018 | 08:43 PM
AK4x4's Avatar
AK4x4
The tire will be about 2.5" taller and as a result the truck will sit 1.25" higher. Russ
Old Jan 3, 2019 | 12:43 PM
Tex51's Avatar
Tex51
I don't know the metric tire thing but I have a 2006 F4x4 with the 4 door full cab and that little 5.5 bed on it. I put a leveling kit on it and I have 33" tires and they work fine with no rubbing. I was using the truck in the mountains in Colorado elk hunting before moving back to Texas it went in some rough and very rocky places.
the cleaner
Apr 21, 2015 05:30 AM
kwaskow
Mar 26, 2015 06:48 PM
351Cleveland C4
13
Oct 1, 2014 10:17 PM
MadFrank81
Apr 12, 2010 08:45 PM
ITDave
1997 - 2003 F150
Apr 5, 2005 08:05 AM
