I recently bought myself my first F250. She needs a bunch of work done to her (mostly interior) and I have some questions. Can anyone tell me what's missing from the rear doors in the attached photo?
I obviously realize the panels are missing - but there seems to be more than just a couple of panels missing. I'm trying to compile a list of parts I need to get them operational again.
Thanks
Window track/regulator appear to be there. Could be just how the picture was taken, but I don't see a single wire running through. Even if you don't have power windows or locks, you'd at a minimum have wires for the door ajar/dome light sensor. Aside from the panel, there is usually like a plastic or rubber sheet that goes between the sheet metal and door panel.
Yeah, never been in a 2016 F250, but yeah, you definitely appear to be missing the door handle. Probably should've noticed that before.
I wasn't gonna ask before, but now I gotta know. Where did you get a truck with an interior this stripped? Only thing that comes to mind when I look at it and what its missing plus the chewed up front seat is police K9 vehicle...?
Ha - You were close! I picked her up cheap (I think!) in an in an Auction. Seller was the Fish and wildlife dept. No idea why the blanked out second row. Pick it up later this week so will maybe figure that out then.
That's so helpful! thank you! really appreciate the help!
If you want the actual part number, stay off the Ford Parts website and go to one of the dealer sites such as Tasca or AutoNation/White Bear Lake Ford. Ford part site might be good for the bolts and nuts numbers.
You will get similar breakdown and a better parts list with actual part numbers.
