Questions on coolant
Old Nov 10, 2018 | 05:27 PM
Bohen's Avatar
Bohen
It was brought to my attention that the orange coolant used in our diesels tends to clogged the EGR valves through the cylinder walls will erode them and eat through the head gasket. I was recommended to get the green one anyone heard of this situation thanks
Old Nov 10, 2018 | 05:43 PM
ford390gashog's Avatar
ford390gashog
Let me guess a "friend of a friend" said this ? There is no truth in it. Make sure you do check the coolant and add the correct ford additive.
Old Nov 10, 2018 | 06:13 PM
kper05's Avatar
kper05
VC-3-B Specialty Orange is the only coolant you should have in your 6.7L PSD.
Old Nov 10, 2018 | 06:23 PM
senix's Avatar
senix
you can run this, it has the ford spec on it.
senix's Avatar
senix
Run your truck and tow with it.
BTW it is not a 6.0
Old Nov 10, 2018 | 06:28 PM
mptjelgin's Avatar
mptjelgin
Not so fast! My 2019 F-350 6.7L came with a supplement to the Capacities and Specifications listing a new coolant for the 2019's. It is Motorcraft Yellow, VC-13DL-G.
No additive strength checking or additives required. Scheduled Maintenance interval 200,000 miles (or ten years).
Old Nov 10, 2018 | 07:05 PM
lynnmor's Avatar
lynnmor
Gold, Orange, now Yellow, no chance for confusion.
Here is a chart: Coolant
Old Nov 10, 2018 | 07:21 PM
Just Strokin's Avatar
Just Strokin
Wonders if users of the Orange coolant can do a flush and fill with the Yellow.
Old Nov 10, 2018 | 08:05 PM
kper05's Avatar
kper05
That's sure to cause some confusion even at a dealer but this seems like a change for the better.
Old Nov 10, 2018 | 08:07 PM
mptjelgin's Avatar
mptjelgin
No doubt. My dealer gave me their own "cheat sheet" of 6.7L diesel tips and they didn't even have the current coolant listed!
Old Nov 10, 2018 | 09:09 PM
Bohen's Avatar
Bohen
It's interesting because he had said that it was on the 6.0 . Was this an issue on those models like I said this is all new to me on the coolant situation I just broke 60,000 miles on my truck
Old Nov 11, 2018 | 09:56 AM
Painted Horse's Avatar
Painted Horse
Yes, the 6.0L has some problems with the EGR cooler plugging
The 6.7 got a new OAT (Organic Acid Technology) based coolant that has no Nitrates like the previous generation of coolants.
The new coolant has Carbolyxe ( how every you spell it) in it that coat the metal and prevent corrosion. Hence the need to periodically check your coolant and make sure the anti corrosion additives are still strong enough to protect the engine. You will see a "Check Coolant" message every 15,000 miles or so. Get your test strips out and check the coolant.
It's great to hear that the 19's have moved on to a newer version of the coolant.
Old Nov 11, 2018 | 11:47 AM
69cj's Avatar
69cj
As Just Strokin asked, Wonder if the new coolant can be used retroactively?
Old Nov 12, 2018 | 07:10 AM
Bohen's Avatar
Bohen
So does anyone know if switching to the green or the yellow is good better than the orange just trying to figure this stuff out is confusing happy Veterans Day I know it's a little late
Old Nov 12, 2018 | 07:45 AM
Painted Horse
You don't want to run anything that is Silca or Nitrate based in the 6.7L engines.
You do want to run coolant that is OAT based.
The Old Green Coolant was run in the old 7.3L and early 6.0L engines.
The Yellow was in the later 6.0L and 6.4L engines. Both are Silca based.
Read or watch the below to get up to speed.
http://www.powerstrokediesel.com/doc...nformation.pdf
