Headlight switch
Old Nov 8, 2018 | 08:41 PM
Hotrod350's Avatar
Hotrod350
Headlight switch
I am currently working on getting my headlights reattached and came across a strange issue. With my driver headlight plugged in I am testing to make sure it works before I button everything up. My headlight is off when the switch is pushed all the way in. It turns on when I pull the switch out one click. But the high beams won't engage. When I pull the switch all the way out the headlight is on and the dimmer switch works. Is this proper operation or is one click out on the light switch supposed to be parking lights only? I am using an American auto wire wiring harness.
Old Nov 8, 2018 | 08:58 PM
abe's Avatar
abe
In is off.
First click is parking lights only.
Second click is headlights, both high and low beam, no parking lights.
Oldb's Avatar
Oldb
So is the switch correct for the year of your truck, or a switch that came with the Harness? All the ford switches I have had were off pushed in, park and tail 1st click and headlamps and tail 2nd click or all the way out. Rotation in 1st or 2nd click changed the intensity of the instrument lights and all the way to the right would turn on the dome. It could be the way American Auto designed the harness to allow low beams on one click. Wish I could offer more.
B
Old Nov 8, 2018 | 09:15 PM
Moe Craig's Avatar
Moe Craig
one out is parking taillights only! all the way out is your headlights.
Old Nov 8, 2018 | 09:19 PM
Hotrod350's Avatar
Hotrod350
Thought this was the case the multi meter also never lies. Low beams are shorted to parking lights
Old Nov 8, 2018 | 09:22 PM
Hotrod350's Avatar
Hotrod350
In a wierd twist of fate both low and high beams are shorted to park lights
Old Nov 8, 2018 | 10:08 PM
Hotrod350's Avatar
Hotrod350
So after about 45 minutes of waiving my multi meter around everything works properly now . Which means the short went away while I was wiggling wires or the spot where it shorted got way too many amps and melted until there was no short .Both are bad. But! My truck has one working light. Would do the other but it is snowing and 10 at night.
Old Nov 9, 2018 | 02:49 PM
petemcl's Avatar
petemcl
Originally Posted by Hotrod350
S. . .the short went away while I was wiggling wires . . .
Don't worry. It will come back . . . at the most inconvenient time.
Old Nov 10, 2018 | 01:05 PM
Mixer man's Avatar
Mixer man
I'll second that.
Old Nov 10, 2018 | 04:50 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I worked in the copier industry as a service manager for over 24 years.
I always told the techs, if they didn't know they fixed the problem, they didn't.
It will definitely be back.
Old Nov 10, 2018 | 06:54 PM
Hotrod350's Avatar
Hotrod350
I have no doubt that it will be back. But until then
With led ring I am going to use as daylight running lights
pgr380
Aug 25, 2017 05:41 AM
69bluebeauty
13
Dec 14, 2012 01:05 PM
get_nick
Sep 13, 2010 05:36 PM
Dutch123
1978 - 1996 Big Bronco
15
Feb 23, 2007 08:36 AM
