New style Con Rod
Old Nov 10, 2018 | 04:27 PM
RedRage's Avatar
RedRage
Mechanic said he looked with a scope and the rods did not have balance pads.
Old Nov 13, 2018 | 05:30 PM
RedRage's Avatar
RedRage
Had a chance to compare both rods and I don't think the new one is stronger. From the side, the old rod looks narrow compared to the new rod. But the new rod looks very skinny
from the other angle while the old rod looks much beefier. Looks like each rod has the same amount of metal but is just a different design from a different manufacturer. In other words the new rod is just cheaper.
Old Dec 4, 2018 | 03:55 PM
17f2fiddy's Avatar
17f2fiddy
This entire rod situation is confusing...if my vin starts with HEC that means I have the new style rods correct?
Old Dec 4, 2018 | 06:11 PM
HDSlowride's Avatar
HDSlowride
It's the last five numbers. Must be a larger number than 90000.
For instance mine is GEA95755
Old Dec 4, 2018 | 06:51 PM
UGA33's Avatar
UGA33
Correct. You will have the larger rods.
Old Dec 4, 2018 | 07:04 PM
dirthawg's Avatar
dirthawg
But.....if your truck is a 2016 with a 90000+ vin it will still have the older rods yes?
Old Dec 4, 2018 | 07:12 PM
17f2fiddy's Avatar
17f2fiddy
i have HEC64731 build date 1/3/17 so i do believe i would have the "bigger" rods
this correct @UGA33? "If you have a VIN of HEAxxxxx to HEB89999, it will have the smaller rods. HEB90000+ will have the bigger rods."
Old Dec 4, 2018 | 07:49 PM
UGA33's Avatar
UGA33
That is correct.
chukar
Mar 20, 2016 02:10 AM
fabieber
Dec 20, 2015 12:51 AM
Golden210
Oct 23, 2014 09:37 PM
5_labsownus
West Virginia Chapter
Apr 2, 2007 10:11 PM
Rebel4x4
Offroad & 4x4
Jan 15, 2003 09:24 PM
