carburetor sins....
https://www.ford-trucks.com/forums/6...n-a-300-a.html
https://fordsix.com/viewtopic.php?t=67681
https://www.ford-trucks.com/forums/1...et-anyone.html
In all reality, a Quadrajet is not a GM carb. It's a Rochester. GM just happened to use them. Just like Holley isn't a Ford carb, although that's what came on Ford engines.
Even if it WAS, the QJ is a good carb. They just have a bad rap due to some of the (fixable) issues they had.
Hope it works out great!
There is a fellow - Tom Lowe - who makes three barrels out of Holley four barrels by blocking off one of the primaries completely. That is an interesting compromise. That would take a 600 vacuum secondary down to around 450 cfm - about perfect.
I wouldn't worry about them being too big. I've even run a squarebore 600cfm Holley on mine for a number of years, and it drove quite well (with MUCH larger primaries than that QJ would have). I could tell my throttle wasn't as "crisp" as it could be, but it drove just fine. I also got my best gas mileage with it (19mpg on a few trips and 15mpg around town).
Technically, a 600cfm carb would have 300cfm primaries.
Cfm requirements are:
CFM = (RPM * Displacement) / 3456
So, RPM is:
RPM = (CFM * 3456) / Displacement
With 300cfm primaries, that's 3456 RPMs where the secondaries need to start opening.
On a quadrajet, they're MUCH smaller, probably around 150 - 200cfm, which would mean the secondaries would start opening around 2000 - 2500 RPMs, which seems just about right. They'd never open up all the way, but they probably didn't on most engines they were installed on from the factory anyway.
They can be sensitive to fuel pressure. So I always run a fuel pressure regulator. Even with a mechanical fuel pump.
The primaries on a QJ are around 180 - 220cfm, which is more akin to the size of the Holley 390cfm's primaries. Then, you have all the secondaries you want. Who cares if you don't use it all?
The 600's are cheap and readily available. People are just about giving them away used. And for some reason they seem easier to get running good. I've never had any issue getting a 300 to run good with a 500-600cfm 4V carb.
I've never liked the 390 cfm 4V on a 300. They can be a royal PITA to get running good. They seem way more troublesome then the larger 4V. Many years ago I ran the 390 4V on a 300. I was never happy with the performance. I swapped over to a 500 cfm 4V and was much happier. I've owned a few 390's. The only time I was really happy with one was when I ran it on a 2.3L OHC 4 cylinder in a Mustang II I use to own. I don't know too many people that have ran both a 390 & a 500 or 600cfrm 4V and preferred the 390. Usually the guys that like the 390's haven't run a 500 or 600 on a 300.
Now I'd rather run a large 2V over the 390 cfm 4V any day of the week! And 2-2V carbs is even better! The 2-2V is about the best set up I've ran on a 240/300.
If I remember correctly, and I don't feel like looking up the research to get the exact numbers, but the primaries flow just under 200cfm, iirc. I have run both the 750 and the 800 on my 300. If I were you, I'd check the vertical serial # behind the throttle. You'll be better off with one that begins with 1705. That means it is one of the last models, the end product of engineering evolution, right before they went electric, and made from 1975-1980. That model will not have the leaky bowl plugs. You can google the #'s and find out what it came oem on, and that will help you set it up when rebuilding. See, qjets are turned/were tuned in the factory for diff. applications by swapping air bleed restrictions, jets, m.rods, springs, etc. GM put a 750cfm qjet on everything from a 230ci engine to a 500ci caddy monster.
There is a great forum that will help a lot. Google Cliff Ruggles and that will get you to the forum. The Qjet is a good carb, but if you go half way on the rebuild, you're asking for trouble. Word to the wise: Because each qjet is tuned precisely to a particular engine, try to find one that came to an engine close in displacement to yours. That will make it easier to tune. Also, stay away from the qjets that have stickers from the mass rebuilders on them. Usually, those shops mix and match components, making turning nearly impossible for a mere mortal. After having spent more than a year rebuilding, changing air bleeds, jets, springs, metering rods, air bleed restrictions, enlaring air bleeds, taking the carb off and reinstalling, I would say this: Use the Summit or paypal credit option and buy a nice used holley or the Summit 500 cfm 4v. If you don't like the eddy carbs, you'll hate the qjets. They are more complicated that the eddies. Good luck.
I'm gunna go on a bit. What I found with the qjet is that everyone rants about the small primaries and the great mpg they produce. That is true, if you drive as if there is an egg between your foot and the pedal. Small primaries are great, but as soon as you get on it a bit, the booster opens to feed the engine, and there went your mpg.
Check your throttle shaft for play. Worn shafts/housings are common, and make tuning fun. You can bush the shaft.
Here is another problem area on the qjets. Dirt catches in the base of these idle tubes, and few remove and replace when they rebuild. Then when the carb doesn't run right they give it bad names.
If you look closely at the photo below, you can see a small restriction in the main air bleed in the top of the carb, the air horn. That is one of the many things Rochester changed to tune the qjet to specific engines. Those can be drilled to lean out the mix, or can be replaced with restrictions with smaller orifices to richen the mix.
have fun!
... Anyways, my procrastination aside, i got the carb on the truck and couldn't be happier with the performance i've gained from it! I still need to fix a couple things on the engine before i can actually tune it, but from the start it was great! much better than an Edelbroke in my opinion.
