HPOP Non-Serviceable plug replaced, now only 300psi
#32
#36
Thanks Everyone!
I've certainly learned a lot from lurking, and researching, and tearing everything apart 3 times, more than I ever wanted to know.
I still don't quite understand the function of that check ball, based on my issues it would seem that it helps pressure build when warm (?). Anti-siphon-back valve?
I ask because I fear I may have gouged it ever so slightly trying to dig it out of there, and not wanting to wait another 3 weeks for parts from the US, I put it back.
It may be cranking ever so slightly longer before it fires, maybe 1.5 seconds, but it has been months since I pulled it apart, so my memories may be wrong. Also Air may not be fully worked out yet.
Regardless, If someone can describe it's function, that would be wonderful!
#37
Oh, and if anyone ever needs to 3D print an IPR wrench, I've posted my design files here:
https://www.thingiverse.com/thing:3246049
#38
when you change out the HPO lines i have heard you remove the check *****. When i change to the CNC lines they used a different type of fitting, flare, vs the ford OEM type. not sure what the purpose of the check ball is but I don't have them and get a quick 1-2 sec crank time. might check some old post on this as well..
https://cncfab.us/i-30497598-cnc-fab...hpopw-hpx.html
#39
The check ball he found loctite on is absolutely, 100% still required and has zero correlation to the check valves in the outlet fittings.
Everlanders
1999 to 2016 Super Duty
11-07-2018 10:30 AM
caveman44
04-03-2012 09:08 PM
