HPOP Non-Serviceable plug replaced, now only 300psi - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 11-07-2018, 11:21 AM
Everlanders's Avatar
Everlanders
Everlanders is offline
Everlanders is gaining momentum as a positive member of FTE.
Thumbs down HPOP Non-Serviceable plug replaced, now only 300psi
In an effort to seal the mystery oil leak in my (2003 F-550, 7.3) galley, I ordered new o-ring sets for the turbo pedestal, high pressure oil pump and fuel bowl.
Also opened up and cleaned out the IPR, new O-rings, and new long thread non serviceable plug.
Unfortunately, after reinstalling, I'm only getting 300 PSI of high pressure oil when cranking.
I'm doing this work at a friend's Farm Shop, and he suggested purging the air from the lines by pull starting it with his tractor. After about 10 seconds at 1000rpm, it fired right up and after about 2 minutes was idling pretty nice. I went for a rip up and down the grid road for about half an hour, and then let it idle for about an hour as we had supper. I neglected to observe the high pressure oil ICP while it was running, I assumed we had just purged the air from the lines and everything was back to normal.
Unfortunately, when the engine is stopped, it will not start again... Still only 300 PSI
If we pull start it with the tractor, it fires up within half a second at 1000 RPM...
I'm baffled as to why it runs with gobs of power when it is running, but won't fire on it's own...
It doesn't seem like a bad IPR to me... And it was running fantastic before I went after the oil leak...
As I understand it, a bad IPR will give only low pressure oil levels, approximately 80 psi?
Does any of this ring any bells for anyone?
Old 11-07-2018, 11:57 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Unplug the icp then try and fire her up
Old 11-07-2018, 12:03 PM
Everlanders
I did, No Dice.
Old 11-07-2018, 12:34 PM
Chevota_72
Chevota_72 is offline
Chevota_72 is starting off with a positive reputation.
What is your battery voltage when cranking? Low batteries may prevent it from starting while cranking but without the starter drawing the voltage down will allow it to start when pulled.
Old 11-07-2018, 12:39 PM
Everlanders
Good Tip, But the batteries were both replaced 3 weeks prior and kept on a battery maintainer as I did the work... I didn't measure the voltage while cranking, but you can hear in the videos above that it's spinning over quick. I'm sure they're fine, but I'll add that to the list of things to double check next time I go out there. Thanks
Edit: Also, that second video was shot that same night, It was running for ~1.5 hours, and moments later wouldn't start.
Old 11-07-2018, 01:14 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Colorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to beholdColorado350 is a splendid one to behold
I’m just going to throw some stuff out there...did you knock the tin nut off the IPR? Oil in ICP? Oil level good? Starter good?
Old 11-07-2018, 01:32 PM
Everlanders
  • New Tin Nut, Thread Locked on, I was in there yesterday, hoping that I'd mixed up the EBPV and IPR connections (I hadn't), And I didn't notice it was loose. But I will add it to the list of things to double check next time I drive out there.
  • New ICP, replaced this summer as a precaution because it still had the old style one on there. Also I'm getting valid ICP measurements in the Torque app (video above). I'll measure voltage, and also swap the ICP with the original I kept as a spare and report back.
  • Fresh 15-40 to the top of the hashmarks.
  • Starter has never been a problem, spins fast (see videos above)... OBDII data shows 200RPM which seems like a low number, but sounds fast/normal.
Thanks all for the tips guys, keep them coming, It's an hour drive to go out there with poor internet access, so I want to be armed with all the good ideas before I go.
Old 11-07-2018, 02:00 PM
IDI-Charlie's Avatar
IDI-Charlie
IDI-Charlie is offline
IDI-Charlie has a very good reputation on FTE.IDI-Charlie has a very good reputation on FTE.IDI-Charlie has a very good reputation on FTE.IDI-Charlie has a very good reputation on FTE.
The HPOP shaft's nut torqued down correctly?
Old 11-07-2018, 02:29 PM
Everlanders
Funny you mention, That was yesterday's roadtrip, I did torque the nut bolt to 95ft/lbs originally, but yesterday I took it 1/32 of a turn past that... about 105ft/lb in case my cheap torque wrench was junk. ( I think my wrench is actually fine, because at 95ft/lbs the engine starts to turn over and needs the crank held - this lines up with what others have said.)
But sadly that was not it...
I did pull out the check valves from the fittings when I did the HPOP o-rings, the online consensus seemed to agree they were not needed. Further, yesterday I called DieselOrings (who's kits I used), and they didn't seem to think that it was contributing to the problem either. But what are the chances that the check valves were making the difference between starting pressure and not? Perhaps my HPOP was/is worn and just riding the edge of acceptable starting pressure and pulling the check valves put it over the edge. It seemed fine before, easily getting up to 3000PSI+ on hard acceleration.
Old 11-07-2018, 02:38 PM
duck fan's Avatar
duck fan
duck fan is offline
Because racetruck
duck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant futureduck fan has a brilliant future
Did you lose the check ball inside the hpop? Sounds like the problem.
Old 11-07-2018, 02:43 PM
Everlanders
I suppose the only way to test low oil pump pressure due to missing check valves is with fittings like Diesel Tech Ron uses at 3:14 in this video? Where would you find such? All I'm getting online is the Air Pressure style for finding leaks.
Old 11-07-2018, 02:53 PM
Everlanders
I don't think I dropped the ball , I knew that was a potential problem before I started, and was very careful to get it put back in it's little home with the edge filter going over it. I had the body of the pump in the vice shaft pointing down as I reinstalled the ball, edge filter and plug.
I can send the borescope in the the IPR hole to confirm, But thought before I get everything oily again I'd ask and see if the symptoms (300psi when cranking) indicated something specific.
Old 11-07-2018, 10:09 PM
timmyboy76's Avatar
timmyboy76
I removed the cv's when i had my pump out for resealing..
Anyway of tryn anutha ipr?
Old 11-07-2018, 11:45 PM
coax9952's Avatar
coax9952
coax9952 is offline
Athletic Supporter
coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.coax9952 has a very good reputation on FTE.
I need to check my numbers but I think you have to have 500 RPM Minimum for the PCM to make fire.... I need to find my stats.
Old 11-08-2018, 09:21 AM
Everlanders
Did you mean HPOP PSI or RPM?
500 PSI is absolutely correct, When pulling it with the tractor, that's the magic number where it fires right up... if you meant 500 RPM then the app may not have been measuring correctly or updating fast enough. I say this because the starter sounds fine, it's spinning as fast as it ever has. (please have a listen in post #1)
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
