HPOP Non-Serviceable plug replaced, now only 300psi
  #31
Old 12-09-2018, 04:31 PM
Everlanders's Avatar
Everlanders
Everlanders is offline
Last edited by Everlanders; 12-13-2018 at 08:47 AM. Reason: Double posted text in error.
  #32
Old 12-09-2018, 05:39 PM
Sous's Avatar
Sous
Sous is online now
Received 4,572 Likes on 2,900 Posts
Nicely done sir!
  #33
Old 12-09-2018, 10:33 PM
coax9952's Avatar
coax9952
coax9952 is offline
I gotta say it....You win the " How The Hell did that Happen?" award for the year!
  #34
Old 12-10-2018, 11:15 AM
TheBigBee's Avatar
TheBigBee
TheBigBee is offline
Congrats man that is a hard one to track down. Glad your up and running again.
  #35
Old 12-10-2018, 11:46 AM
z31freakify's Avatar
z31freakify
z31freakify is online now
Received 1,206 Likes on 829 Posts
Dude, awesome sure was hard to track down the culprit, glad you are up and running.
  #36
Old 12-13-2018, 08:56 AM
Everlanders
Thanks Everyone!
I've certainly learned a lot from lurking, and researching, and tearing everything apart 3 times, more than I ever wanted to know.
I still don't quite understand the function of that check ball, based on my issues it would seem that it helps pressure build when warm (?). Anti-siphon-back valve?
I ask because I fear I may have gouged it ever so slightly trying to dig it out of there, and not wanting to wait another 3 weeks for parts from the US, I put it back.
It may be cranking ever so slightly longer before it fires, maybe 1.5 seconds, but it has been months since I pulled it apart, so my memories may be wrong. Also Air may not be fully worked out yet.
Regardless, If someone can describe it's function, that would be wonderful!
  #37
Old 12-13-2018, 09:07 AM
Everlanders
Oh, and if anyone ever needs to 3D print an IPR wrench, I've posted my design files here:
https://www.thingiverse.com/thing:3246049
  #38
Old 12-22-2018, 04:36 PM
carl2591's Avatar
carl2591
carl2591 is online now
when you change out the HPO lines i have heard you remove the check *****. When i change to the CNC lines they used a different type of fitting, flare, vs the ford OEM type. not sure what the purpose of the check ball is but I don't have them and get a quick 1-2 sec crank time. might check some old post on this as well..
https://cncfab.us/i-30497598-cnc-fab...hpopw-hpx.html
  #39
Old 12-22-2018, 05:07 PM
Sous's Avatar
Sous
Sous is online now
There is a big difference between the check ball in the HPOP and the check valves (discs) in the HPOP outlet fittings.
The check ball he found loctite on is absolutely, 100% still required and has zero correlation to the check valves in the outlet fittings.
Everlanders
1999 to 2016 Super Duty
11-07-2018 10:30 AM
maretta
09-25-2018 10:17 AM
caveman44
04-03-2012 09:08 PM
fomoconut
11-01-2010 09:15 PM
alfars
21
02-09-2010 11:28 AM
Quick Reply: HPOP Non-Serviceable plug replaced, now only 300psi
